Requesting hivemind help finding some hair
in The Commons
Hi pals - I’m hoping the hive mine can help me find two hairs. It’s got a g9 figure and I have until now just been searching g9 hairs, but they both quite short so an autofitted g8 hair would probably work fine
Hair 1 - Audrey Hepburn vibes
Second one is a very slicked back hair with a small bun:
Any recommendations would be greatly appreciated!
Toyen is where I look for classic styles, and dforce French Twist might be a good match for Audrey.
Thanks for the tip - I'll keep an eye on their stuff. Really looking for something matching the bangs on the pics above as well.
Are you part of the marketing team? They just dropped this hair for you.
https://www.daz3d.com/dforce-juliette-casual-updo-for-genesis-9
A few more ideas:
https://www.daz3d.com/elegant-bun-hair-for-genesis-8-and-genesis-3-females
https://www.daz3d.com/librarian-hair-for-genesis-8-females
https://www.daz3d.com/ak-graceful-buns-hair-for-genesis-9
https://www.renderosity.com/marketplace/products/128735/daily-bun-hair-for-genesis-3-and-8-females
https://www.renderosity.com/marketplace/products/127767/ada-hair-for-genesis-8-females
The bangs aren't quite right, but you better believe I immediately bought that haha! It's good!
(Image removed by mod https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity)
Thanks! Will check some of these out!
This hair mashup does not exist, but probably should:
https://www.daz3d.com/addy-lyla-for-genesis-8-female
I played with the Elegant Bun Hair today and there are a number of poses for the bangs that shorten or lengthen them. One comes close to the Audrey Hepburn look.
The bun is not a French Twist but if there was a hair in the store, it might come with an Editorial License. That style was associated with Ms. Hepburn and her elegant look. Of course as she grew, her hair changed from a shaggy pixie look to a bangless bun when she went into the field for UNICEF in her later years.
But if you combine the bangs from the Elegant Bun Hair for G8F with https://www.daz3d.com/fantasy-hair-for-genesis-3-female-s and close off the cutout opacity on 'Fantasy Hair_UV2' and use a transmap hair shader to blend the two hairs together, you might come up with something close. The back is a little complex, but depending on your angle, doable. I fit both on G8.1F for testing without issue.
Mary
