DAZ Studio 4.9 - question on original (vendor) content folders with selfmade jpegs in it
cosmo71cosmo71 Posts: 3,609
edited January 2016 in The Commons
I have a some original vendor folders in my content in which I have copied and edited textures of the original textures, will installing DS4.9 has any influence on this?
I have the edited textures in these original folders because I often just change the diffuse maps so it is quite easier to have all maps of a clothe or hair item in one folder, also the edited versions.
Post edited by cosmo71 on
  • LeanaLeana Posts: 13,499
    edited January 2016
    Installing 4.9 will not change anything to the content you have already installed.
    New content installed with DIM or manual install will continue to work in the way it did before.
    For new content installed via Connect (encrypted or not) I'd suggest storing your own files outside the Connect folder and using smart content / categories / links to have them useable from the same place in your library.
    Post edited by Leana on
  • cosmo71cosmo71 Posts: 3,609
    edited January 2016
    So long I can I will nothing download via connect, I will use the dim so long as I can. Never used smart content or anything like this.
    Well everything will work as it did before for you then.
    good to hear.
    ah read wink
    I will wait until most of the bugs will be fixed, so I will download 4.9 in one or two month
