macOS Sequoia
Has anyone been brave enough to try DAZ Sudio on the new macOS 15.0?  Got to love those x.0 releases. :)
Lloyd
  • If DAZ Studio is your main application and you are prefering iray rendering, stay away from Mac or any AMD GPUs, for they are not supported by the iray render engine.
    You will need a NVidea GPU instead.
  • nemesis10nemesis10 Posts: 4,037
    As someone who does work on a Mac and currently using Sequoia, it is working fine (with the usual touchiness with menu items that hopefully will be fixed in DS 5).
  • ElorElor Posts: 4,236
    So as stable / unstable as it was in Sonoma, which mean less stable that it was in Ventura ?
    About that level... it is an issue with how it handles menus... with careful planning, I have found it workable (i do all the menu stuff first like adding smoothing attributes or using a eye posing script then do stuff like simulations); other than that I found it works fine.
  • lloyflloyf Posts: 30
    So I took the plunge and upgraded to Sequoia and the new version of DAZ Studio.  I know bad idea updating two things at the same time.  It does seem Studio is more likely to fail to launch than before, sometimes it takes three or more attempts to launch.  Not sure which, if either, is the cause (back to the bad idea of making two changes at the same time).
    The menu behavior seems to have changed.  I am not seeing the "ghosting" of the menu items any more.  I could still make it crash by moving around in the menus a lot with out selecting anything.  I am not sure if this is an improvement as with the "ghosting" there was an indication bad things were about to happen.
    Overall there really isn't that much of a change so I won't try to revert either.
    Lloyd
    Lloyd
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log#4_22_1_216
    • On macOS 14+, the main menu bar for the application has been moved from the system menu bar to inside the main window (like the Windows version)
      • This is a workaround for a conflict between Qt and macOS that causes an infinite loop to be entered into and ultimately a crash
  • I have installed MacOS Sequoia (Official Release) on Mac Mini M2.
    Sequoia runs a bit smoother than Sonoma and the “DAZ-Menu-Problem“ is fixed.
    DAZ 4.22.0.16, 4.22.0.19 and 4.22.1.202 with no Problems on Mac Mini M2 (Sequoia).
  • Notice: DAZ-Applications and Database are on external SSD.
    Just mentioning that Boost for Daz exists.  https://boostfordaz.infinite-compute.com
  • lclairelclaire Posts: 29
    Robert Bou is right, and Boost has solved all my issues for rendering — and without a huge outlay for hardware. Highly, highly recommended.
  • memcneil70memcneil70 Posts: 6,168
    I have no idea of 'Boost for Daz' but is it applicable since DAZ 2025 Alpha was released? I for one do not have issues rendering on my MacMiniM4 on either the Beta or the Alpha.
