Map Transfer not work
I'm trying to bake a texture from one UV to the other UV. That is what is written in the log file:
WARNING: QAccessibleWidget::rect: This implementation does not support subelements! (ID 7 unknown for QWidget)
WARNING: QAccessibleWidget::rect: This implementation does not support subelements! (ID 17 unknown for QAbstractScrollAreaWidget)
  • vwranglervwrangler Posts: 5,053
    Which version of Studio are you using? Which operating system? Which UV sets?
    I've done a fair amount of map transfer with 4.8, and I don't remember seeing that message, although it doesn't always work, either.
  • smaysmay Posts: 233
    edited January 2016
    I use 4.8, transfer map from M7 to my UV set. Perhaps I'm doing something wrong.
    630 x 620 - 70K
    Post edited by smay on
    edited January 2016
    So what happens when you place the torso texture on the right onto the Template on the left? Is that when the error message appears?
    476 x 626 - 30K
    Post edited by vwrangler on
    Thanks vwrangler, now everything works. yes
