Why does DAZ use so little GPU while animation rendering and how can it be fixed?
huntergeenhuntergeen Posts: 43
edited September 2024 in Daz Studio Discussion
[Why does DAZ use so little GPU while animation rendering and how can it be fixed?]
  • Richard HaseltineRichard Haseltine Posts: 111,359
    Please put your question in the post body and the title - Daz 3D Forums
    Task Manager is not useful by default. Instead of looking at that mini-graph go into the  main area of the tab and chnage one of the graphs to CUDA, if present, or Compute 0.
  • crosswindcrosswind Posts: 10,249
    Highly recommend GPU-Z
  • PadonePadone Posts: 4,314
    Probably it has to reload textures between frames and recompute the scene data by the camera angle, which is done with the cpu, after that the gpu comes into play for rendering. In a typical scene the rendering takes much more time than initializing, but then it depends on your render settings and the scene itself. Also if you have a very slow cpu and a very fast gpu that could be it.
