Shiny faces.
Hi there.  I picked Welda up some time ago,https://www.daz3d.com/sase-welda-for-topsy-8 ,  and love using this cutie for sci fi battle stuff, but each time I render, her face is quite glossy, though from the neck down, all is fine, no gloss.  I'm I forgetting to do something? surprise
Thanks.smiley
  • I don't think it's you - I've just loaded here up and OOTB her face is pretty shiny :/
  • crosswindcrosswind Posts: 10,351
    edited September 2024
    Go to Surfaces pane, Ctrl + Select Face, Ears and Torso surfaces, locate the slot Specular Lobe 2 Roughness, increase the value to 0.40 or more... or just crank up the value in Dual Lobe Specular Ratio  to 0.9+... the bigger it is, the closer the roughness will be approching Lobe 1 Roughness. Also zero Glossy Layered Weight, useless....
    Then finetune them as needed ~~
    2560 x 1392 - 2M
    Post edited by crosswind on
