v8 animation to v4
i need  transfer some  animation  of v8  to use in v4  because  i  have  a lower ram  memory   and is more  faster use  v4  charactar  is  possible  exist  some  asset / tool  script  etc  to buy  or  free that can convert animatio of v8  to genesis or genesis 2  or V4
  • crosswindcrosswind Posts: 10,330
    You may consider this product - https://www.daz3d.com/bone-minion-for-genesis-8-and-81-poses-for-generation-4 which can converts both static pose and poses in animated range.
  • gocuzerogocuzero Posts: 74
    thanks will test
    edited August 2024
    i buy it  and  WORK PERFECTLY   exist  the same  for v3  figure  gen 3  michael 3  aiko3  etc????  v3 to v8  v8 to v3?
    Post edited by gocuzero on
    Great !  Unfortunately, AFAIK, there's no Bone Minion product supports Generation 3 to whichever Genesis xx ~~
  • AinmAinm Posts: 764
    There's a bone minion genesis 3 to 8 converter: https://www.daz3d.com/bone-minion-for-genesis-3-poses-for-genesis-8-and-81
    you typically have to buy two converters to go in both directions or a few to chain converter products together across generations.
    This product is pretty expensive but it's also universal across genesis figures: https://www.daz3d.com/mocap
    I've used it to transfer poses and animations between all sorts of generations. I think it's the only one that seems to be able to do that as a single product, so it's actually cheaper than buying many other other products. It's not quite as simple to use, but has worked very well for me. It sort of does expressions too, but not fully. I've not tested that part beyond the superficial, but it does seem to do slight expression transfers that other products can't do. I think it calculates the bones offset by an expression morph (vendor probably adjusted rigging to shape?) rather than the morph shape itself. I was getting eye and mouth movements out of it, anyway.
  • richardandtracyrichardandtracy Posts: 8,155
    edited August 2024
    There is a freebie pose transfer script that does V3-G8 and another G8-V3. They can occasionally be a little unreliable due to the wide differences in generations, and often needs limits turned off. It doesn't help that they are not targetted at animations, but they may be useful.
    Regards,
    Richard
    Post edited by richardandtracy on
    Regards,
    Richard
    thanks will test.
