DIM does not install correctly
Hello, my DIM does not install correctly, i cant`find my new content in DAZ after installing. In Addition, my old content is displayed in DIM at the top left and is not installed, althouh it can be found in DAZ. I would be grateful for help LG Inga
1896 x 600 - 89K
  • felisfelis Posts: 6,642
    Have you moved your content libraries?
  • frank0314frank0314 Posts: 15,116
    I seems like you probably moved you content library and didn't link it back up with the new llocation in DIM and DS.
  • Hello, the new content should be installed on a new disk, have shown the way see pictures, the new content is not exported there.
    1000 x 998 - 160K
    1000 x 954 - 200K
    And if you look in that path, is your content not installed there?
    Did you start installing everything fresh onto the new drive or did you copy some of the old installs to the new drive as well? If you look in the location of where the manifest files are being installed; is the folder empty or does it have the files of the products you installed?
  • there are several in the manifest
    745 x 745 - 104K
    Regarding finding it in DS, have you defined the new path in your content library.
    Regarding old content listed as not installed in DIM. Have you changed the manifest location in DIM, but not moved the old manifest files?
  • I work with multiple disks and the old content is on another one, the manifest is there too. I moved the new one to the manifest of the new disk
    DIM uses the manifest files to track what is installed and where.
    So if you have changed the manifest path to the new one, DIM will not know that the old content is installed.
    So if you just have created a new content library, then you can move your manifest files to the new location, then DIM will know it is installed.
  • thank you is displayed in  DIM
