Error message - missing file with Wukong
Hi,
I get the following message when loading Wukong "data/Daz 3D/Built-in Content/OmniSurface/OmniHair Root-Tip Blend.dsf" is missing
  • GordigGordig Posts: 10,822
    Are you using DS 4.22, and have you upgraded your default resources?
  • felisfelis Posts: 6,622
    edited July 2024
    That should be part of Daz Studio default ressources and is the new strand based hair shader.
    Which version of Daz Studio are you using?
    Post edited by felis on
  • FantastArtFantastArt Posts: 427
    Ok, I see. I'm still using 4.20 because I'm always afraid about upgrades. so this is the problem
     Yes this is the problem. I'm still using 4.20
  • crosswindcrosswind Posts: 10,351
    You can install the latest DS Public Build while keeping your older version of DS. Then you can make Omni shader work with the latest Default Resources package.
  • Hi. So, if I update my version of Daz: I should top recieving this same error message? BC I am getting this on a lot of different hairs I have DL'd.
    HELP!
  • enemyhqenemyhq Posts: 3
    edited October 2025
    HELP!
    It didn't work. I am still getting the same error message on a lot of new hairs I grabbed.
    Frusterating.
  • LeanaLeana Posts: 13,632
    You need to install the latest version of Daz Studio Default resources pack too.
