Using a separate content directory
Dark-Elf
I've had to reinstall Studio and my content is all installed on a different drive. I can't recall how to set up the content directory to access the other drive. Can someone please help?
Right click on the "content library" tab, select Content Directory Manager(CDM), Select the "current set", select the appropriate content type(orange box around it), Daz content, poser contet, etc.
Click the Add button, navigate to the appripriate drive/directories, select and click accept in CDM.
I'd recommend creating a new set or copy the current directories, as you can make a backup of your CDM file(ContentDirectoryManager.dsx) and if you need to change drives, you just have to edit the path in the file.
