Windows Action Window Sizing
Hello,
I'm here to see if anyone else has a problem with using a product. If this is in the wrong place, please let me know so I can correct the forum.
The product is the Mirror Geometry (Gen 8) and when using it, all goes well until the step where I need to enter information into a windows information type pop up window. The issue is the window is way too small to see the options I need to select. A script is running so I am unable to scale the window larger.
I didn't know if there was a windows trick to resize the window in the midst of a script running.
Because I can't enter the required information, the product doesn't work.
Again, if this is in the wrong place or if I need to submit a ticket, please let me know so I am educated in the proper way to ask questions of this nature.
Thank you,
Artsy
  • crosswindcrosswind Posts: 10,357
    To be exact, what is the Window that you mentioned ? Update Base Geometry window in screenshot 1 ? or OBJ Import Options window in screenshot 2 ?  or any other window I've never seen before... ?
    1471 x 1294 - 222K
    1471 x 1294 - 202K
  • ArtsyDragonArtsyDragon Posts: 682
    It's the second one. I can see the others just fine.
    Well, that dialogue is on top of all other dialogues, just follow the attached screenshot to enlarge it. Even if you could not change the size of it, just click on Accept button, the default settings will do.
    843 x 531 - 42K
    edited July 2024
    I'll try enlarging it again. I tried just accepting the settings but the hair product really failed to convert. I tried to do it a second time but that failed even worse. LOL
    Thank you for the suggestions.
    Post edited by ArtsyDragon on
    edited July 2024
    Which hair product were you converting ?
    Post edited by crosswind on
