Render 99% never ends
I'm trying to render a scene with M4 in daz studio 4.5 but the yield to 99% and never ends. Even in simple scenes.
With the genesis does not occur.
Anyone have this same problem?
Thanks
Thanks
someone may have better info than me, but I have had this happen once or twice. All i can suggest is you troubleshoot the issue.
It could be your M4 clothes are causing an issue. try rendering him nude. I've had items cause the render to stick at 99% because of some of the smoothing used. (not sure if you are using smoothing but you can cut that off and try that way too)
Is your M4 morphed or using special shaders? Try it without.
Also be sure to check the log file under help. it may yield some clues.
You can also just cancel the render at 99% and save it. 1% isn't going to make a visible difference. Well thats what I do when it hangs and I get impatient:) Not a solution to the problem, but it works.
does that work when rendering to disc?
Explain rendering to disc.
'Rendering to disc' presumably means rendering directly to file rather than to a window. It should give the same result, however whether or not interrupting will be visible will likely depend on the bucket order, or the precise bucket where the issue is occurring, if it's in the middle of someone's face....
The other thing to do is to check the log file to see if it identifies what the problem is.
Oh. No I always render to window.
