Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
    • Creative Tools
    • AI Scene Enhancer
    • Generative Credits
    • Enterprise Tools
    • Synthetic Training Data
    • Physical AI
Download Studio
Notifications
Loading...
    • Categories
    • Recent Discussions
How to split an object without disrupting vertex order?
RobertDyRobertDy Posts: 277
June 2024 edited June 2024 in Blender Discussion
So I'm very new to blender, and I'm thinking of making a zip morph for a dress that originally doesn't have a zip. So basically the part to be zipped would have to be split when the morph is off, and then combined when it's on. With my limited knowledge I could delete faces of the mesh for zip open and then use the grab tool for zip closed, but obviously that won't work because deleting parts of the mesh is a huge no-no for importing back into DAZ. How do I go about doing this?
Post edited by RobertDy on June 2024
  • LeanaLeana Posts: 13,744
    June 2024
    A morph can't remove or split polygons, only distort them.
    If the sides of the zip aren't separate in the first place I don't think you can "open" it with only a morph, because:
    • there would be polygons joining both sides, which would need to be gone when the zip is open
    • there might even be vertices which are parts of both "sides"
    If both sides are "independant enough" (ie no shared vertices) one option might be to get an "open effect" would be to move the vertices corresponding to each side, then make the polygons in the middle invisible (assign them to another surface or use a map make them transparent).
    Another option could be to create a geograft to replace the closed zip with one where the parts are separate, and create an open morph for that.
  • crosswindcrosswind Posts: 10,361
    June 2024
    Splitting a welded garment in trim/zip area almost turns out to be a remaking of the garment. Technically it's doable but it'll be pretty cumbersome. If I were you, I would rather make a new one in MD or Blender.
    The trick is from very beginning, you should make a garment with the trim/zip area closed but geometry unwelded, then it'll be easy to make Open morphs as well as necessary rigging on it.
  • RobertDyRobertDy Posts: 277
    June 2024
    Thanks Leana and crosswind. I get that it's undoable, but Leana's geograft suggestion is the most likely solution, thanks so much!
  • felisfelis Posts: 6,679
    June 2024
    You could split the vertexes in the middle of the zipper, if that is possible.
    When imported to Daz Studio it will be a new item, where you have to run Transfer Utility.
    If you don't touch the UV or surface names (materials) you can reuse textures, but you have to load them on the original first, and then you can copy to the new one.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
