Can't render
I spent all day setting up a scene. Now when I hit render I get an "can't render" error message. This is at the bottom of the log file:
2024-06-27 17:32:12.345 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - API:DATABASE ::   1.0   API    db   warn : Transaction is released without being committed or aborted. Automatically aborting.
2024-06-27 17:32:19.072 [INFO] :: Total Rendering Time: 12.13 seconds
What the hell is going on?
  • Richard HaseltineRichard Haseltine Posts: 111,325
    Have you tried saving the scene and restarting DStudio?
  • lou_harperlou_harper Posts: 1,163
    Many times. :(
    edited June 2024
    I have to reboot the PC every time too, becasue DAZ doesn't close properly or crashes after a failed render attempt. And as I do, I get this error message. But then the pc restarts without me clicking on anything.
    2059 x 1817 - 280K
    Post edited by lou_harper on
    After much tedious testing I zeroed down to one prop. Once I removed it from the scene it rendered. :/
  • crosswindcrosswind Posts: 10,244
    Hmm, it's an asset issue...
  • barbultbarbult Posts: 27,474
    What prop is it? Save the rest of us from having this problem.
    It was the cauldron from Halloween Props, but I used it many times before without a problem. Also tested it again with a fresh scene and no issue. So something must've gotten corrupted.
    NvContainer... would most likely be part of the nVidia driver, which might well explain why the issue has only just started. Which (or witch) Halloween props?
    A set by Hypertaf–not in the store anymore. But as I said, it works fine.
