• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Having trouble with Golden Palace materials transferring over with Diffeo
josiahmora20josiahmora20 Posts: 83
June 2024 edited June 2024 in Blender Discussion
It's strange to me, I made a character in Daz last week and when I used Diffeo to blender i had seperate materials for all the Golden Palace parts located under the mesh of my genesis 9 character. This week I made a new character, went through the same process of applying the GP materials in Daz (even tried copying the exact surfaces over from the first character) but when I import the second character I don't get those materials (see picture). I tried reimporting the first character to make sure I didn't just accidently change an import setting but that character still works.
In Blender if I remove the output of character 1's Torso some of that area turns black, if I remove the output of character 2 the whole thing turns black.
Literally everything looks the same between both characters in Daz. Both surfaces tabs look identical.
Can someone help? not sure where the problem is coming from.
Update: Solved? still very weird, but I found that if I unselect "Merge UV Layers" on character 2's import it creates those materials seperatly, but for character 1 if I merge the UV layers I still get the seperate materials.
261 x 300 - 15K
257 x 242 - 14K
Post edited by josiahmora20 on June 2024
  • PadonePadone Posts: 4,325
    June 2024
    Hard to tell without more information. You could check if there's any difference in the uv maps of the two figures, or try not to merge materials in easy import, or try not to prune node trees in the global settings. Of course also check the blender console for errors. If nothing comes out then you could upload a test scene as simple as possible and I may be able to give it a look.
  • josiahmora20josiahmora20 Posts: 83
    June 2024
    Today it just randomly created those materials upon import with Merge Uv Layers selected ¯\_(ツ)_/¯
  • jwcjaygainesjwcjaygaines Posts: 72
    June 2024
    Hi Josiah! You're right: you have to uncheck the "Merge Materials" option on the sidebar (right below the Viewport Color area). I ran into this issue awhile back and was losing my mind trying to figure it out. Mine wasn't for GP or DCK, but for separate facial areas. Pupils and Irises were merging with Sclera, and Lips and Ears were merging with Face. When it comes to any genitalia in Blender, I usually just use one texture for the whole thing anyhow. I find having too many for the same piece of geometry which are essentially the same takes up too much memory when saving, and I aim to keep all my model files under 10K if at all possible.
    September 2024 edited September 2024
    That didnt work for me! I continue to struggle with this. Today I was at it for hours trying every setting, then decided to re save the root path from Daz and then finally the geografts objects merged but the materials still arent seperated. definitely a bug..
    Post edited by josiahmora20 on September 2024
    September 2024
    Look at that, for no reason it just worked. changed nothing.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
