• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
How to export from Daz3D to Blender/Godot for GameDev?
ipbvipbv Posts: 1
June 2024 in Blender Discussion
I want to use the characters I create in Daz Studio as a game asset in Godot. To do this, I need the characters to be in a T-pose during import. With a test character I've attempted this in two ways, encountering the following issues:
  • Direct FBX Character Export:
    • Textures were imported, but the shading was overly glossy, and transparency was lost.
    • Clothing did not align with the custom T-pose, instead sticking to the default A-pose. I couldn't find an option to disable 'Convert Clothing to Static Geometry.'
  •     Blender Bridge:
    • Shading was better, but not all textures/materials were imported. The body texture and material were particularly missing. Even when using 'copy' path mode with 'embedded texture' enabled, as suggested in some tutorials, it still didn’t work.
Has anyone successfully imported Daz3D characters into Godot or prepared them as game assets in Blender? Any advice on this pipeline would be appreciated.
Versions:
    DAZ Studio    4.22
    Blender          4.1
    Godot             4.1.3
  • crosswindcrosswind Posts: 10,343
    June 2024
    As for FBX format, the most accountable DS version with enhanced FBX exporter is the latest DS Public Build version. And you have to tweak shader nodes yourself. For the clothing, you need to tick Merge Followers.
    With DTB bridge, it'll be better but still limited in terms of materials, morphing process, posing, rigging, etc. Suggest you use Diffeomorphic Daz Importer.
    As for Godot, I don't use it but AFAIK the best imported format for it is glTF 2.0 and Blender support exporting to such a format without using any add-on. So you may give it a try.
  • PadonePadone Posts: 4,360
    June 2024
    Importing iray materials in blender is not trivial, depending on the material complexity. Then again I suppose you will have to use eevee in Godot being it a game engine, which of course has its own limitations over iray. That basically means you have to fix some materials and textures yourself so what you are experiencing is normal.
    That said you can try diffeomorphic with the "extended principled" material option, that provides a fair good conversion for eevee. Meaning you will have to fix only a few materials.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Material Methods
  • ipbvipbv Posts: 1
    June 2024
    Thank you for your replies. I tried using the Diffeomorphic Daz Importer along with a glTF 2.0 export from Blender. Similar to the DTB bridge, the character was successfully imported with no issues, as far as I could tell at this stage. Both methods managed to transfer all textures into Blender, however only with Diffeomorphic Daz Importer all those textures could also be transfered over to Godot.
    As Padone pointed out, the Iray materials weren't imported correctly. As this is quite normal when importing I guess its something to live with and fine as long as only some material settings need tweaking, it's manageable. My main concern here was getting all textures for into Godot, which now works.
    In my last post I forgot to mention clipping issues with some clothes in Blender. Does the Diffeomorphic Importer or Daz Studio offer some options to fix those?
    June 2024
    You can use a smooth modifier in daz studio, then set it to interactive before exporting, this way it will be baked in the dbz. Otherwise you can use shrinkwrap in blender, that's similar to smooth in daz studio but tends to work better. Otherwise you can sculpt out as needed.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
