Michael 2
MoogeeMoogee Posts: 74
Ok, this might seem like an odd question considering the varity of models sold by Daz. I was looking through some old hardrives and found a load of M2/M3 stuff. M2 was the first figure I worked with and kinda miss him. I like the semi-toon quality of the model. Would he still work in the current Daz Studio and if so how would I install him as the files are in exe format rather then zip file format?
Many thanks in advance,
Andrew
  • MelanieLMelanieL Posts: 7,881
    Assuming you bought him from the Daz store, he will be in your Product Library as a zip file HERE. If you install with DIM, you can find him there too.
    He will still work but you will need to load him from his .cr2 file under Content Library - Poser Format - Characters (I can't remember exactly wher under that folder, probably DAZ People?)
    His materials will not look great in DS without a bit of tweaking.
  • jjoynerjjoyner Posts: 875
    @Moogee,
    The Michael 2 download/install in your Product Library is now a zip file and can be installed via DIM; I still have the olde executable files too.  Hopefully, you have more wardrobe that Michael 2 can wear.  I have nothing specifically for Michael 2 and most of the little that I have for Michael 3 fits badly without a lot of potential tweaking.  The best that I could find in my small Michael 3 wardrobe asses that did not require too much tweaking to get barely passable results was a spacesuit.   Attached are images of a very basic viewport scene and rendered image of Michael 2 wearing the Michael 3 spacesuit.
    1200 x 650 - 146K
    1000 x 1000 - 602K
