Break/Line in Hair
There's a break or a line in the hair.  I've seen this on other hair assets before, but this is:
https://www.daz3d.com/fe-k-medium-hair-vol-02-for-genesis-9
Any suggestions?
2560 x 1440 - 3M
  • felisfelis Posts: 6,651
    I don't have it.
    Is that with any color?
    It looks like there might be a tiling of 2.
  • Richard HaseltineRichard Haseltine Posts: 112,049
    Is there a morph applied that is enlarging the head of the figure?
  • MrRogerSmithMrRogerSmith Posts: 175
    edited May 2024
    felis said:
    I don't have it.
    Yes, it's with any color.
    Richard, I did try zeroing the figure shape so there were no morphs (base Gen 9) and the problem persisted.
    After doing some more tests I realized it's caused by the Head node moving either side-side or twisting.  Head bending is fine, and Neck 1 and Neck 2 movements are also fine.  Is this something I can fix?
    Edit: Actually head bending also is a problem.
    2379 x 922 - 2M
    2413 x 990 - 2M
    2553 x 1048 - 2M
    Post edited by MrRogerSmith on
    That looks to be a rigging limitation. You could report it to Technical Support, but they may well reply that it is intended to eb used with the bones in unison (the Pose controls on the Body node don't seem to cause the same issue).
    Okay, I will file a ticket, thank you for the response.
  • Olo_OrdinaireOlo_Ordinaire Posts: 763
    I have found that hair from this vendor is often problematic and is difficult to use if the character does anything but look straight forward.  I've stopped buying from this vendor because of these rigging issues.
