Corrupt File
I have a file that closes Hex when every I select a particular face on one of the objects. I think if I delete the face it will be fine, but when I go to select it, Hex crashes... do you think there is anyway I can prevent this?
I think I may be able to delete the whole object, if so is there a way to copy/import an object from one Hex file and paste it into another?
Sounds like you have what I called a "twisted n-gon" in a post I made a while back.
If that's the case, then find the vertex that's out of order and drag it so that the n-gon is no longer folded or twisted.
