• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Shade Smooth Issue in 4.1
Mart1n71Mart1n71 Posts: 132
April 2024 in Blender Discussion
I've just updated my Blender to v4.1 from 3.5 and I'm seeing some odd behaviour on shade smooth. When I right click and select shade smooth the mesh appears all lumpy, where as in 3.5 it was nice and smooth. Selecting Sculpt Mode makes it all smooth as per 3.5, but going back to object or edit mode makes everying look lumpy again.
1080 x 657 - 162K
1080 x 657 - 177K
  • PadonePadone Posts: 4,342
    April 2024
    You can check for sharp edges in edit mode, that are new in 4.1. Or be sure that "keep sharp edges" is disabled when you apply shade smooth.
    288 x 69 - 4K
  • Mart1n71Mart1n71 Posts: 132
    April 2024
    No, I tried that, plus various options in the new Shade Smooth By Angle option.
    903 x 1080 - 195K
  • therealragingoniontherealragingonion Posts: 2
    April 2024
    I'm having the same issue. I usually don't have to smooth shade the model when I import via Wavefront, as I assume shading data is carried over (I'll have to review that now). However, if I do any light sculpting on the mesh, it's breaking the smooth surface and auto-smooth is just making everything worse. The only solution I've found is to add a sub surface modifier, set to Catmull-Clark, with the Smooth by Angle modifier placed after it. This isn't going to go well on higher detail models if I have to sub-divide an already heavy mesh just to be able to make minor modifications.
  • hardwire666hardwire666 Posts: 79
    April 2024
    Just a thought but I would play with the rendering settings for the view port. Looks a lot like Ambient Occlusion errors that happen when the settings are cranked. Could also be 1000000% wrong. Like I said just a thought.
    April 2024
    So I think I've found the fix for this. When you import a model, go into edit mode and select the entire model. Then, in the toolbar at the top, select "Mesh" and then "Normals" (You can also just use the hotkey Alt+N to bring up the "Normals" menu). Under the "Normals" menu, select "Reset Vectors." Then exit edit mode and enable "Shade Smooth." I've tested this on a model imported with no subdivisions and a model with 2 subdivisions and both are being smoothed as expected, even with the "Smooth by Angle" modifier enabled. It seems that Blender's smoothing operation is no longer able to properly render the mesh normal data that's being imported from Daz. I'm not sure if you're using Diffeomorphic but if you happen to use the Out-of-Box export options in Daz, you can uncheck the "Write Normals" option in the export menu to skip having to reset vectors in Blender every time you import a model.
    April 2024 edited April 2024
    Unless there's custom normals you want to keep for some low resolution meshes, usually you don't export/import normals, especially for figures since normals are recomputed anyway for deformations. What I mean is just don't import normals, if this is the issue.
    Post edited by Padone on April 2024
    April 2024
    Thanks a lot guys. It turns out it was having the calculate normals ticked when exporting from Daz that was causing the issue, since unchecking that box things have been looking much smoother.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
