• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Trying to fix skirt distortion but having trouble
echristopherclarkechristopherclark Posts: 290
April 2024 edited April 2024 in Blender Discussion
Attached is a screenshot of a skirt, originally designed for Genesis 8/8.1 that I fitted to a G9 character. I brought it into Blender to try and smooth out the distortion near the groin area, but while I was able to smooth the underskirt surface, I could not get the smooth tool to do anything on the main problem. Is this mesh just so messed up that I need to something else with it first (or instead)?
640 x 480 - 66K
Post edited by echristopherclark on April 2024
  • echristopherclarkechristopherclark Posts: 290
    April 2024
    Oh man, like 10 seconds after posting this, I figured out I was doing something wrong in Blender. I just need to learn that program better. Sorry for taking up space here.
    April 2024
    Or not? I don't know. It still looks super weird in that region, even after figuring out how to smooth it.
    3840 x 2160 - 1M
  • frank0314frank0314 Posts: 15,115
    that looks like inverted polyies or the inside polyies are pulled through the front. What does the wireframe or mesh look like in those areas?
    Post edited by frank0314 on April 2024
    April 2024
    Does this help?
    3840 x 2160 - 3M
    April 2024
    One more. I found the "face orientation" option in Blender and it seems like everything is facing the right way?
    3840 x 2160 - 2M
  • barbultbarbult Posts: 27,624
    April 2024
    Maybe you should move your thread to the Blender forum to get more Blender specific help. https://www.daz3d.com/forums/categories/blender-discussion
    April 2024
    Done. Thanks for the suggestion.
  • PadonePadone Posts: 4,361
    April 2024
    In the skirt geometry you can see blue lines, those are hard edges new in blender 4.1, that were probably imported with some autosmooth in blender. You can use "edge > clear sharp" in edit mode to get rid of them, since the smooth tool won't do it for you.
    April 2024
    Thanks, Padone. I'll give that a try.
  • HaHHaH Posts: 3
    April 2024
    It's been a few days since this was posted and you may have already gotten this answered on the blender forum, but I have your answer. The cyan-colored edges on your model are "hard edges".Hard edges maintain their sharpness when smooth shading is turned on. To remove the hard edges, follow these steps:
    Select the skirt and go into Edit Mode>turn on edge selection > press Shift while selecting all of the cyan edges (the selected cyan edges turn a whiter cyan when selected) > click "Edge" dropdown > click "Clear Sharp" > the cyan edges now turn orange (with the last selected edge turning white) > your model is now entirely smooth.
    Above "Clear Sharp" is "Mark Sharp," which adds the cyan sharp edges to objects. Sometimes when importing an object into blender, sharp edges on the model appear. I'm not entirely sure why, but it might have to do with exporting from the one 3D software to another. It doesn't happen all the time, but if it does, the sharp objects happen in strange places (such as on random parts of a character's face). Its best practice to check models for things such as face orientation, sharp edges, loose geometry (random vertices floating around), and do a limited dissolve (merge overlapping/identical faces) when you import models. (To delete loose edges: Mesh > Clean Up > Delete Loose. To do Limited Dissolve: Mesh > Clean Up > Merge by Distance.) I hope your skirt project has been going well.
    546 x 723 - 113K
  • crosswindcrosswind Posts: 10,343
    The closer G8F's skirt was made to the crotch area, the more chance you'll get that "triangulated distortion" projected from G9's body shape (crotch shape) after auto-fitting...
    The best and quickest way to fix the distortion is to use Smooth Brush with Sculpt mode, as well as Flat / Grab brushes etc. to finetune the details as needed. Then import OBJ file back to the skirt as a fix morph with Morph Loader Pro, or directly update the base geometry of the skirt with OBJ file.
    Post edited by crosswind on April 2024
    April 2024
    Thanks for the tips here. I've kinda had to forget about this for a while in order to work on another project, but I'm hoping to try some of these solutions soon.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
