Missing files
I bought some from outside of Daz Studio, I put them in 'My Daz 3D Library' via 'people' 'data' etc
However it won't load because of "Missing files". Something tell me I shouldn't put them in "My Daz 3D lIbrary" in the first place. I am really confused and a bit stressed. which one should I put them ? Sorry if I don't make sense.
  • Richard HaseltineRichard Haseltine Posts: 112,018
    Assuming that the My Daz 3D Library is a content direcotry, and that the Data and Runtime folders are merging with the folders thata re already there (not going into a sub-folder) it should work, if the content is set up correctly and if you have any required products installed.
  • sir_sephysir_sephy Posts: 49
    I solved the problem (so it seems). All I did is drag files to drop on texture folder via runtime folder manually and it's worked. I have so many missing files to sort out. Thank you for explained. I apprentice it.
