Action Zero Trigger
StratDragon
Action Zero Pose trigger no longer works in the latest version of studio. The dialog will only allow you to restore or zero, but not cancel the action or close the dialog. Is there a fix?
No fix so far... you have to pick one option then undo.... I've been also wondering why there's no cancel button...
According to the main thread, and some posts to my now closed rant about the subject, there's a change with genesis 9 that causes some issues with using zero functions.
My solution was to just use a script to zero poses and create a custom action and short cut. Since I'm not using g9, it's not an issue for me.
If you need it for other functions, can't help as i don't use those.
It isn't only Genesis 9.
Are you suing http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/actions/action_trigger/start#example_with_settings
Thus far, i haven't been able to come up with anything that's causing an issue with using the zero functions, except for genesis 9 related.
Could you point me to something about this?
I'm just trying to understand what the issue, in relation to other figures is.
