Transfer Utility error
bluelight specialbluelight special Posts: 34
edited March 2024 in Daz Studio Discussion
[Transfer Utility is] It's causing the clothing OBJ to rise up after the transfer, even after playing with all of the "Current" and "Default" settings for both the Source and the Target. I even used it on older characters that were previously successful. Something appears to be broken in both Daz Studion 4.22.0.15 and .16.
  • crosswindcrosswind Posts: 10,313
    So the clothing was made on a non Base figure and, with Transfer Utility, you chose "Current" from Source - Item Shape and ticked "Reverse Source Shape from Target", but the rigging result was still wrong ?
  • bluelight specialbluelight special Posts: 34
    edited March 2024
    Yeah. After some testing, it only seems to be effecting my custom Genesis 9 figures.
    Post edited by bluelight special on
  • lilweeplilweep Posts: 2,877
    edited March 2024
    yes, that's why they said to reverse source shape from target...
    Post edited by lilweep on
  • I know to click the Reverse. On both the Transfer Utility and for a Morph Target. I thought I'd be clever and just load a morph target of the pre-rigged OBJ, and that worked. Until i moved the model.
    Make sure your transformations are baked before doing Transfer utility. (I.e., make sure your clothing transformation parameters are at X,Y,Z = 0,0,0)
    If it's not at zero, you need to export and reimport the clothing.
  • The problem was Geografts. Had to Unfit them, Transfer Utility, and then Fit them back again.
    Thanks for the responses.
    if you say so
