Get Caps Lock State
Hi! Is there any way to find out Caps / Num / Scroll Lock state?
modifierKeyState doesn't work. isKeyDown and isKeySequenceDown show if the key is actually pressed.
Do you have any ideas?
  • OmnifluxOmniflux Posts: 442
    You cannot currently do this in DAZ Script. Checking the state of these is not supported in QT.
    If you write a plugin with the SDK then you can use OS specific methods to check, and then export these methods to the scripting environment and then you can do this...
