Lip Syncing?
msolomonmsolomon Posts: 213
edited February 2024 in Daz Studio Discussion
I realize this question has probably been asked many times but how are some of you getting Lip Syncing in DAZ 64 bit?
Post edited by msolomon on
  • LOL mostly by using the 32bit to save as pose files
    I do use PoseRecorder for Genesis 8 sometimes
    Mimic Live not so much
  • wolf359wolf359 Posts: 3,955
    There is also Anilip 2 for G2-G8
    https://www.daz3d.com/anilip-2
  • msolomonmsolomon Posts: 213
    Thanks Wendy, I am using Bforartists now, a better version of Blender. Unfortunatly, it has nothing like Carrara's Mimc. I can bring Daz models into Bforartists (morphs and all) but still trying to figure out how to do mimic like lip syncing. B4 has a plug in Called Human Generator. I have been using a MoCap app on my iphone for lip syncing and that has worked very well.
    This is a screen shot of the Bforartists UI and I model I created in it. Thanks to all my years in Carrara, becoming funtional in B4 was doable.
    1920 x 1080 - 2M
    This is a marketing render I created for a non profit in Cleveland. Bforartists has all the tools of Blender, plus more, but a much easier UI.  I must admit though, with all the modern day tools it has, Carrara still has a few tools it does not. Carrara tends to do some of the same things, just easier. Like the asset browser in Carrara is much easier to use. The constaints in Carrara are more intuative. Key frame interpalation is more straight forward.
    The advantage to B4 is the constant upgrades and updates. The devs are more approachable. I can send them a message and they will get back to me immdediately. I also have access to a huge amount of tallent who can help me with projects.
    All that said, I still miss Carrara.
    3000 x 1688 - 6M
    Another render from the same assignment.
    3000 x 1688 - 5M
    Thanks, I will check it out.
    Do you know if Anilip works on 64 bit Daz?
    Yes I have the product running on DS 64 bit.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,389
    BTW Carrara mimic exports as BVH with Fenric's plugin using bones for Genesis 3, 8, 8.1 and 9
    (as long as you have the fixed characters for the first 3)
    it works in DAZ studio, in fact Carrara BVH export is the only BVH I can get to work on those latter figures
    That is a great idea. I have mimic and it works great.
    Great, thanks.
    Where can I get Fenrics plug-ins?
    WendyLuvsCatz said:
    https://www.daz3d.com/forums/discussion/380916/fenric-s-plugins/p1
    Thanks Wendy. I've been out of the community so long I didn't know Fenric was down. Very sorry to here that. I don't think Daz has any idea how many lost opportunities they lost turning thier back on Carrara.
  • Edited posts to fix quotes - generally hitting return/enter twice will break out of a quote (or other paragraph-level formatting) but if not there will be a red line with a return symbol under the quote (or other foramtting) when you hover the mouse over that area, click the symbol to break out of the formatting.
  • DartanbeckDartanbeck Posts: 22,149
    Playing around with Anilip 2 for the first time
    More of a complete demonstration of the workflow used above
    Since then I'm starting to find that Anilip 2's results are definitely worth saving as an animated viseme pose file before changing a thing. It does a really decent job without much editing at all - if any. Of course, I suppose that depends upon how we approach the conversion in the first place. For example, I try to keep a single session to a single line - whatever is said without stopping in between.
    So if the line I want spoken has a pause in it, I treat whatever comes before the first pause as a single session in Anilip 2. We don't have to do it this way, but I find that it makes everything more predictable and easier to work with in the end. Sometimes it may even be worth it to run a single word and save that as a single animated viseme pose.
