Developing in the new Version of Microsoft Visual Studio
Hello! I'm new here.
I want to get into creating plugins using the DAZ SDK. I'm working on a Windows 64bit environment. I've downloaded the latest version of the SDK and installed the latest version of Microsoft Visual Studio 2022 Community, but now I see in the documentation that I needed Microsoft Visual Studio 2010. How critical is this? Can I still work in Microsoft Visual C++ 2022?
  • AinmAinm Posts: 764
    You can. I am.
    The key thing is to set the correct options in CMake. I've just closed my computer down, but from memory I used the Visual Studio 14 (2015) generatoe with v100 set in the text field box below. I think it was called arguments or something. I can't remember if I downloaded the VS14 tools separately, if they are downloadable from within Visual Studio 22 installer or if they were already bundled, but rest assured it is possible. I wouldn't want to say it's easy, but it could be - a lot of my trials and tribulations were about figuring out what I needed to do rather than doing anything particularly complicated.
  • This is discussed in the documentation, ./docs/compile_win.html
    While the exact version of the Microsoft Visual Studio IDE used to develop a DAZ Studio plugin can vary (VS 2017 is being used internally at the time of this writing), the application itself is compiled with the Microsoft Visual C++ 2010 (v100) compiler. This is an important detail because it means that in order to avoid compatibility issues with the allocation and/or freeing of memory, any code that is intended to communicate directly with the application must also be compiled with the same compiler. That being said, it is possible for a plugin to act as a "shim" and marshal data between the application and an another library/engine that is compiled with a compiler other than the Microsoft Visual C++ 2010 compiler.
    More recently 2019 and 2022 have been used, but still compiling using the 2010 version.
  • Hello! I use VS 2015. Although I think the 2017 version is the best (just can’t leave my old reliable lady).
    I think it's better to first try to compile the examples supplied with DAZ SDK. They are already configured correctly for Visual Studio. If you start with your own project, then it may not work due to the incorrect location of the SDK and moc compiler folders. It is also easy to make errors in the directives for creating moc files, etc. As a result, you will not find out the real reason why your project did not compile: an error in its creation or incompatibility of the SDK with the new version of Visual Studio.
  • How does one even get their hands on the Visual Studio 2010 Built Tools these days?
    I can't seem to find them anywhere on the internet :)
    Install
    The new (old) toolset should then show up in VS.
    Install
    Brilliant!  Thanks!
    I will give it a try now :)
  • I was able to get Visual Studio 2010 (v100) to show up as a Toolset option in Visual Studio 2022 however, when I try to compile with that toolset I'm getting a bunch of permision denied errors.
    Has anyone encounted this problem?
    1847 x 1194 - 570K
  • https://developercommunity.visualstudio.com/t/VS-2022-Community-access-denied-error-wh/10108969 This thread explains in detail that Visual Studio 2022 sucks. What didn't you like about Visual Studio 2017? All the beauty you see in DAZ Studio was developed in Visual Studio 2010 (or 2012). Do you believe that a big issue will allow you to do even better?
  • We are told that DS has been developed in Visual C++ 6.0, and Visual Studio 2005, 2008, 2010, 2015, 2017, 2019 and 2022 - 2012 has not been used. The SDK refers to 2010 and 2017. Recent work has been done in 2017 and 2022, using the 2010 (v100) compiler for DS 4.x.x.x.
  • Richard, tell whoever gave you this interesting information that we admire them and the product they created. And we strive to be like them. (Hmm, I guessed I needed to program in Visual Studio 6.0, not 2015. That's why I got stuck in my plugin...)
    Calm down there big fella!  I was just asking :)
    I need VS 2022 for Unreal Engine development and getting 2022 and another (ancient) version of VS to happy coexist on the one machine is proving very challenging.  I think I'm going to spin up a virtual machine for Daz plugin development.
    We are told that Daz is careful to install 2010 and its service pack first, then the later versions - ideally, install all versions in ascending order of release to avoid the risks of path errors.
    Thank you.
    Yes, I'm struggling to get everything installed on Windows 11.
    2010 complains about missing .net 4.6, which complains about missing Win 7 SDK. When I try to install .net 4.6 it says it, or a newer version, is already installed and won't proceed.
    I'll keep bashing away at it though :)
  • surrealsurreal Posts: 202
    I stopped using VS2019/2022 for some reason I can no longer remember. I currently use VS2017 however, just did a test compile of one of my plug-in projects using VS2022. Did not get any 'Can not open ...' errors. I did however get some other permission errors (e.g. create/find files).
    To fix I just needed to give VS2022 permission to modify the appropreate folders (Windows Security/Ransomware protection).
    Have not yet had time to check if the compiled dll runs without errors though.
  • If you install Visual Studio 2010 Professional or Ultimate, Windows 7 SDK (and dotnet framework) will be installed automatically.
  • nonesuch00nonesuch00 Posts: 18,846
    edited March 2025
    Yes, that is solved by:
    1) opening your "C:\Program Files\DAZ 3D\DAZStudio4 Public Build" and "C:\Program Files\DAZ 3D\DAZStudio4 Public Build/plugins" (or leave off the Public Build portion if need be) folders via Properties and going to the Security tab and editing the permissions for the two folders to have "Full Control" for the Users\ in the access control list, then when the build process tries to copy the sdk_*.dll files to your DAZ 3D install it can copy them to there, or remove them when you do a make clean.
    1) Oops, my bad, I didn't enlarge your image and thought you were having trouble copying the linked plugin .dll into your DAZ Studio plugin folder. For the problem you have there I have seen in the past sed scripts and other build scripts actually create and/or edit header files depending on both the build environment and the target enviroment so maybe that is your problem there: those scripts are trying to edit those files and don't have permissions.
    I do have a big question though, I can configure and build the Win32 version of the plugins no problem using the above links posted by OmniFlux and VS 2022 Community (or Visual Studio Express 2010), Windows 7.1 SDK, and CMake/CMake-GUI 3.17 but those are 32 bit plugins and I need 64 bit plugins and I have been unable to get CMake-GUI 3.17 to configure cmake files that correctly build for the Visual Studio 2010 x64 64 bit VC compiler/linker/libraries. Anyone have an suggestions? Is there a step by step set of instructions for getting CMake 3.17 or similar to configure the DAZ SDK for 64 bit plugin builds with Visual Studio 2022 Community or Visual Studio Professional 2015 (if I can find my key after a decade past now)? I may have too much Visual Studio 2010/Windows 7.1 SDK installed (I have what OmniFlux posts PLUS Visual Studio Express 2010 installed plus Windows Update did a couple of Service Packs and updates to that after I installed it).
    Post edited by nonesuch00 on
    edited March 2025
    OK, I think I'll just go buy a used copy of MS VS 2010 Professional but before I do I figured I'd ask here one more time:
    I manually set the vsvarsamd64 file
    set VS100COMNTOOLS="C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\Tools\"set PATH="C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\amd64";%PATH%set INCLUDE="C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1\Include";"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\include";%INCLUDE%set LIB="C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1\Lib\x64";"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\lib\amd64";%LIB%echo Environment variables set for VS 2010 VC++ amd64.
    As OmniFlux stated:
    Install
    I've done that and to test I try to compile and link the Windows 7.1 SDK Samples\begin\simple\simple.c console app and I get this error:
    Samples\begin\simple>cl Simple.c /link /VERBOSEMicrosoft (R) C/C++ Optimizing Compiler Version 16.00.40219.01 for x64Copyright (C) Microsoft Corporation.  All rights reserved.Simple.cMicrosoft (R) Incremental Linker Version 10.00.40219.01Copyright (C) Microsoft Corporation.  All rights reserved./out:Simple.exe/VERBOSESimple.objStarting pass 1Processed /DEFAULTLIB:LIBCMTProcessed /DEFAULTLIB:OLDNAMESSearching libraries    Searching C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\lib\amd64\LIBCMT.lib:      Found printf        Referenced in Simple.obj        Loaded LIBCMT.lib(printf.obj)      Found mainCRTStartup        Loaded LIBCMT.lib(crt0.obj)      Found __C_specific_handler        Referenced in LIBCMT.lib(printf.obj)        Referenced in LIBCMT.lib(crt0.obj)        Loaded LIBCMT.lib(chandler.obj)      Found _unlock_file2        Referenced in LIBCMT.lib(printf.obj)        Loaded LIBCMT.lib(_file.obj)      Found _ftbuf        Referenced in LIBCMT.lib(printf.obj)        Loaded LIBCMT.lib(_sftbuf.obj)      Found _output_l        Referenced in LIBCMT.lib(printf.obj)        Loaded LIBCMT.lib(output.obj)      Found _invalid_parameter_noinfo        Referenced in LIBCMT.lib(printf.obj)        Referenced in LIBCMT.lib(output.obj)        Loaded LIBCMT.lib(invarg.obj)      Found _errno        Referenced in LIBCMT.lib(printf.obj)        Referenced in LIBCMT.lib(output.obj)        Loaded LIBCMT.lib(dosmap.obj)      Found _vprintf_l        Referenced in LIBCMT.lib(printf.obj)        Loaded LIBCMT.lib(vprintf.obj)      Found __security_cookie        Referenced in LIBCMT.lib(printf.obj)        Referenced in LIBCMT.lib(output.obj)        Referenced in LIBCMT.lib(invarg.obj)        Loaded LIBCMT.lib(gs_cookie.obj)      Found __CxxSetUnhandledExceptionFilter        Referenced in LIBCMT.lib(crt0.obj)        Loaded LIBCMT.lib(unhandld.obj)      Found __crtExitProcess        Referenced in LIBCMT.lib(crt0.obj)        Loaded LIBCMT.lib(crt0dat.obj)      Found _NMSG_WRITE        Referenced in LIBCMT.lib(crt0.obj)        Referenced in LIBCMT.lib(crt0dat.obj)        Loaded LIBCMT.lib(crt0msg.obj)      Found _XcptFilter        Referenced in LIBCMT.lib(crt0.obj)        Loaded LIBCMT.lib(winxfltr.obj)      Found _setenvp        Referenced in LIBCMT.lib(crt0.obj)        Loaded LIBCMT.lib(stdenvp.obj)      Found _setargv        Referenced in LIBCMT.lib(crt0.obj)        Loaded LIBCMT.lib(stdargv.obj)      Found __crtGetEnvironmentStringsA        Referenced in LIBCMT.lib(crt0.obj)        Loaded LIBCMT.lib(a_env.obj)      Found _ioinit        Referenced in LIBCMT.lib(crt0.obj)        Loaded LIBCMT.lib(ioinit.obj)      Found _RTC_Initialize        Referenced in LIBCMT.lib(crt0.obj)        Loaded LIBCMT.lib(_initsect_.obj)      Found _mtinit        Referenced in LIBCMT.lib(crt0.obj)        Loaded LIBCMT.lib(tidtable.obj)      Found _heap_init        Referenced in LIBCMT.lib(crt0.obj)        Loaded LIBCMT.lib(heapinit.obj)      Found __security_init_cookie        Referenced in LIBCMT.lib(crt0.obj)        Loaded LIBCMT.lib(gs_support.obj)      Found __NLG_Return2        Referenced in LIBCMT.lib(chandler.obj)        Loaded LIBCMT.lib(jmpuwind.obj)      Found _IsNonwritableInCurrentImage        Referenced in LIBCMT.lib(chandler.obj)        Referenced in LIBCMT.lib(crt0dat.obj)        Loaded LIBCMT.lib(pesect.obj)      Found _calloc_crt        Referenced in LIBCMT.lib(_file.obj)        Referenced in LIBCMT.lib(stdenvp.obj)        Referenced in LIBCMT.lib(ioinit.obj)        Referenced in LIBCMT.lib(tidtable.obj)        Loaded LIBCMT.lib(crtheap.obj)      Found free        Referenced in LIBCMT.lib(ioinit.obj)        Referenced in LIBCMT.lib(tidtable.obj)        Referenced in LIBCMT.lib(_file.obj)        Referenced in LIBCMT.lib(output.obj)        Referenced in LIBCMT.lib(stdenvp.obj)        Referenced in LIBCMT.lib(a_env.obj)        Loaded LIBCMT.lib(free.obj)      Found _fcloseall        Referenced in LIBCMT.lib(_file.obj)        Loaded LIBCMT.lib(closeall.obj)      Found _flushall        Referenced in LIBCMT.lib(_file.obj)        Loaded LIBCMT.lib(fflush.obj)      Found _lock        Referenced in LIBCMT.lib(fflush.obj)        Referenced in LIBCMT.lib(_file.obj)        Referenced in LIBCMT.lib(crt0dat.obj)        Referenced in LIBCMT.lib(tidtable.obj)        Referenced in LIBCMT.lib(closeall.obj)        Loaded LIBCMT.lib(mlock.obj)      Found _isatty        Referenced in LIBCMT.lib(_sftbuf.obj)        Loaded LIBCMT.lib(isatty.obj)      Found _fileno        Referenced in LIBCMT.lib(_sftbuf.obj)        Referenced in LIBCMT.lib(output.obj)        Referenced in LIBCMT.lib(fflush.obj)        Loaded LIBCMT.lib(fileno.obj)      Found __updatetmbcinfo        Referenced in LIBCMT.lib(output.obj)        Loaded LIBCMT.lib(mbctype.obj)      Found __updatetlocinfo        Referenced in LIBCMT.lib(output.obj)        Referenced in LIBCMT.lib(mbctype.obj)        Loaded LIBCMT.lib(localref.obj)      Found __globallocalestatus        Referenced in LIBCMT.lib(output.obj)        Referenced in LIBCMT.lib(mbctype.obj)        Referenced in LIBCMT.lib(localref.obj)        Loaded LIBCMT.lib(glstatus.obj)      Found __ptlocinfo        Referenced in LIBCMT.lib(output.obj)        Referenced in LIBCMT.lib(tidtable.obj)        Referenced in LIBCMT.lib(mbctype.obj)        Referenced in LIBCMT.lib(localref.obj)        Loaded LIBCMT.lib(nlsdata2.obj)      Found _flsbuf        Referenced in LIBCMT.lib(output.obj)        Loaded LIBCMT.lib(_flsbuf.obj)      Found __GSHandlerCheck        Referenced in LIBCMT.lib(output.obj)        Referenced in LIBCMT.lib(invarg.obj)        Referenced in LIBCMT.lib(crt0msg.obj)        Referenced in LIBCMT.lib(mbctype.obj)        Loaded LIBCMT.lib(gshandler.obj)      Found _isleadbyte_l        Referenced in LIBCMT.lib(output.obj)        Loaded LIBCMT.lib(_wctype.obj)      Found _cfltcvt_tab        Referenced in LIBCMT.lib(output.obj)        Loaded LIBCMT.lib(cmiscdat.obj)      Found wctomb_s        Referenced in LIBCMT.lib(output.obj)        Loaded LIBCMT.lib(wctomb.obj)      Found strlen        Referenced in LIBCMT.lib(output.obj)        Referenced in LIBCMT.lib(crt0msg.obj)        Referenced in LIBCMT.lib(stdenvp.obj)        Loaded LIBCMT.lib(strlen.obj)      Found __security_check_cookie        Referenced in LIBCMT.lib(gshandler.obj)        Referenced in LIBCMT.lib(output.obj)        Referenced in LIBCMT.lib(invarg.obj)        Referenced in LIBCMT.lib(crt0msg.obj)        Referenced in LIBCMT.lib(mbctype.obj)        Loaded LIBCMT.lib(amdsecgs.obj)      Found __crt_debugger_hook        Referenced in LIBCMT.lib(invarg.obj)        Loaded LIBCMT.lib(dbghook.obj)      Found memset        Referenced in LIBCMT.lib(invarg.obj)        Referenced in LIBCMT.lib(mbctype.obj)        Referenced in LIBCMT.lib(wctomb.obj)        Loaded LIBCMT.lib(memset.obj)      Found _output_s_l        Referenced in LIBCMT.lib(vprintf.obj)        Loaded LIBCMT.lib(outputs.obj)      Found _output_p_l        Referenced in LIBCMT.lib(vprintf.obj)        Loaded LIBCMT.lib(outputp.obj)      Found "void __cdecl terminate(void)" (?terminate@@YAXXZ)        Referenced in LIBCMT.lib(unhandld.obj)        Loaded LIBCMT.lib(hooks.obj)      Found _initp_misc_winsig        Referenced in LIBCMT.lib(crt0dat.obj)        Loaded LIBCMT.lib(winsig.obj)      Found _initp_misc_rand_s        Referenced in LIBCMT.lib(crt0dat.obj)        Loaded LIBCMT.lib(rand_s.obj)      Found _initp_misc_purevirt        Referenced in LIBCMT.lib(crt0dat.obj)        Loaded LIBCMT.lib(inithelp.obj)      Found _initp_heap_handler        Referenced in LIBCMT.lib(crt0dat.obj)        Loaded LIBCMT.lib(handler.obj)      Found __xc_z        Referenced in LIBCMT.lib(crt0dat.obj)        Loaded LIBCMT.lib(crt0init.obj)Processed /DEFAULTLIB:kernel32.lib Processed /DISALLOWLIB:libcmtd.lib Processed /DISALLOWLIB:msvcrt.lib Processed /DISALLOWLIB:msvcrtd.lib      Found atexit        Referenced in LIBCMT.lib(crt0dat.obj)        Loaded LIBCMT.lib(onexit.obj)      Found __crtMessageBoxW        Referenced in LIBCMT.lib(crt0msg.obj)        Loaded LIBCMT.lib(crtmboxw.obj)      Found wcscat_s        Referenced in LIBCMT.lib(crt0msg.obj)        Loaded LIBCMT.lib(wcscat_s.obj)      Found wcsncpy_s        Referenced in LIBCMT.lib(crt0msg.obj)        Loaded LIBCMT.lib(wcsncpy_s.obj)      Found wcslen        Referenced in LIBCMT.lib(crt0msg.obj)        Loaded LIBCMT.lib(wcslen.obj)      Found wcscpy_s        Referenced in LIBCMT.lib(crt0msg.obj)        Loaded LIBCMT.lib(wcscpy_s.obj)      Found _set_error_mode        Referenced in LIBCMT.lib(crt0msg.obj)        Loaded LIBCMT.lib(errmode.obj)      Found strcpy_s        Referenced in LIBCMT.lib(stdenvp.obj)        Loaded LIBCMT.lib(strcpy_s.obj)      Found _ismbblead        Referenced in LIBCMT.lib(stdargv.obj)        Loaded LIBCMT.lib(ismbbyte.obj)      Found malloc        Referenced in LIBCMT.lib(crtheap.obj)        Loaded LIBCMT.lib(malloc.obj)      Found _calloc_impl        Referenced in LIBCMT.lib(crtheap.obj)        Loaded LIBCMT.lib(calloc_impl.obj)      Found realloc        Referenced in LIBCMT.lib(crtheap.obj)        Loaded LIBCMT.lib(realloc.obj)      Found _recalloc        Referenced in LIBCMT.lib(crtheap.obj)        Loaded LIBCMT.lib(recalloc.obj)      Found fclose        Referenced in LIBCMT.lib(closeall.obj)        Loaded LIBCMT.lib(fclose.obj)      Found _write        Referenced in LIBCMT.lib(fflush.obj)        Referenced in LIBCMT.lib(_flsbuf.obj)        Loaded LIBCMT.lib(write.obj)      Found _commit        Referenced in LIBCMT.lib(fflush.obj)        Loaded LIBCMT.lib(commit.obj)      Found __crtLCMapStringA        Referenced in LIBCMT.lib(mbctype.obj)        Loaded LIBCMT.lib(a_map.obj)      Found __crtGetStringTypeA        Referenced in LIBCMT.lib(mbctype.obj)        Loaded LIBCMT.lib(a_str.obj)      Found memcpy        Referenced in LIBCMT.lib(mbctype.obj)        Referenced in LIBCMT.lib(winsig.obj)        Loaded LIBCMT.lib(memcpy.obj)      Found __free_lc_time        Referenced in LIBCMT.lib(localref.obj)        Loaded LIBCMT.lib(inittime.obj)      Found __free_lconv_num        Referenced in LIBCMT.lib(localref.obj)        Loaded LIBCMT.lib(initnum.obj)      Found __free_lconv_mon        Referenced in LIBCMT.lib(localref.obj)        Loaded LIBCMT.lib(initmon.obj)      Found __lconv_c        Referenced in LIBCMT.lib(localref.obj)        Referenced in LIBCMT.lib(nlsdata2.obj)        Referenced in LIBCMT.lib(initnum.obj)        Referenced in LIBCMT.lib(initmon.obj)        Loaded LIBCMT.lib(lconv.obj)      Found __newcumap        Referenced in LIBCMT.lib(nlsdata2.obj)        Loaded LIBCMT.lib(ctype.obj)      Found _lseeki64        Referenced in LIBCMT.lib(_flsbuf.obj)        Loaded LIBCMT.lib(lseeki64.obj)      Found _getbuf        Referenced in LIBCMT.lib(_flsbuf.obj)        Loaded LIBCMT.lib(_getbuf.obj)      Found iswctype        Referenced in LIBCMT.lib(_wctype.obj)        Loaded LIBCMT.lib(iswctype.obj)      Found _fptrap        Referenced in LIBCMT.lib(cmiscdat.obj)        Loaded LIBCMT.lib(crt0fp.obj)      Found ___mb_cur_max_func        Referenced in LIBCMT.lib(wctomb.obj)        Loaded LIBCMT.lib(initctyp.obj)      Found __report_gsfailure        Referenced in LIBCMT.lib(amdsecgs.obj)        Loaded LIBCMT.lib(gs_report.obj)      Found strtol        Referenced in LIBCMT.lib(outputp.obj)        Loaded LIBCMT.lib(strtol.obj)      Found abort        Referenced in LIBCMT.lib(hooks.obj)        Loaded LIBCMT.lib(abort.obj)      Found strncpy_s        Referenced in LIBCMT.lib(inithelp.obj)        Loaded LIBCMT.lib(strncpy_s.obj)      Found __crtGetLocaleInfoA        Referenced in LIBCMT.lib(inithelp.obj)        Loaded LIBCMT.lib(a_loc.obj)      Found _msize        Referenced in LIBCMT.lib(onexit.obj)        Referenced in LIBCMT.lib(recalloc.obj)        Loaded LIBCMT.lib(msize.obj)      Found _newmode        Referenced in LIBCMT.lib(malloc.obj)        Referenced in LIBCMT.lib(calloc_impl.obj)        Referenced in LIBCMT.lib(realloc.obj)        Loaded LIBCMT.lib(_newmode.obj)      Found _close        Referenced in LIBCMT.lib(fclose.obj)        Loaded LIBCMT.lib(close.obj)      Found _freebuf        Referenced in LIBCMT.lib(fclose.obj)        Loaded LIBCMT.lib(_freebuf.obj)      Found _putwch_nolock        Referenced in LIBCMT.lib(write.obj)        Loaded LIBCMT.lib(putwch.obj)      Found mbtowc        Referenced in LIBCMT.lib(write.obj)        Loaded LIBCMT.lib(mbtowc.obj)      Found __chkstk        Referenced in LIBCMT.lib(write.obj)        Referenced in LIBCMT.lib(a_map.obj)        Referenced in LIBCMT.lib(a_str.obj)        Referenced in LIBCMT.lib(a_loc.obj)        Loaded LIBCMT.lib(chkstk.obj)      Found _unlock_fhandle        Referenced in LIBCMT.lib(write.obj)        Referenced in LIBCMT.lib(commit.obj)        Referenced in LIBCMT.lib(lseeki64.obj)        Referenced in LIBCMT.lib(close.obj)        Loaded LIBCMT.lib(osfinfo.obj)      Found _isctype_l        Referenced in LIBCMT.lib(strtol.obj)        Loaded LIBCMT.lib(isctype.obj)      Found __locale_changed        Referenced in LIBCMT.lib(strtol.obj)        Referenced in LIBCMT.lib(isctype.obj)        Loaded LIBCMT.lib(setlocal.obj)      Found __initconout        Referenced in LIBCMT.lib(putwch.obj)        Loaded LIBCMT.lib(initcon.obj)      Found __init_collate        Referenced in LIBCMT.lib(setlocal.obj)        Loaded LIBCMT.lib(initcoll.obj)      Found __mb_cur_max        Referenced in LIBCMT.lib(setlocal.obj)        Loaded LIBCMT.lib(nlsdata1.obj)      Found strcat_s        Referenced in LIBCMT.lib(setlocal.obj)        Loaded LIBCMT.lib(strcat_s.obj)      Found strcspn        Referenced in LIBCMT.lib(setlocal.obj)        Loaded LIBCMT.lib(strcspn.obj)      Found strcmp        Referenced in LIBCMT.lib(setlocal.obj)        Loaded LIBCMT.lib(strcmp.obj)      Found __get_qualified_locale        Referenced in LIBCMT.lib(setlocal.obj)        Loaded LIBCMT.lib(getqloc.obj)      Found memcmp        Referenced in LIBCMT.lib(setlocal.obj)        Loaded LIBCMT.lib(memcmp.obj)      Found strncmp        Referenced in LIBCMT.lib(setlocal.obj)        Loaded LIBCMT.lib(strncmp.obj)      Found strpbrk        Referenced in LIBCMT.lib(setlocal.obj)        Loaded LIBCMT.lib(strpbrk.obj)      Found _stricmp        Referenced in LIBCMT.lib(getqloc.obj)        Loaded LIBCMT.lib(stricmp.obj)      Found atol        Referenced in LIBCMT.lib(getqloc.obj)        Loaded LIBCMT.lib(atox.obj)      Found _strnicmp        Referenced in LIBCMT.lib(getqloc.obj)        Loaded LIBCMT.lib(strnicmp.obj)      Found _itoa_s        Referenced in LIBCMT.lib(getqloc.obj)        Loaded LIBCMT.lib(xtoas.obj)      Found _tolower_l        Referenced in LIBCMT.lib(stricmp.obj)        Referenced in LIBCMT.lib(strnicmp.obj)        Loaded LIBCMT.lib(tolower.obj)      Found _strtoi64        Referenced in LIBCMT.lib(atox.obj)        Loaded LIBCMT.lib(strtoq.obj)    Searching C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\lib\amd64\OLDNAMES.lib:LINK : fatal error LNK1104: cannot open file 'kernel32.lib'
    The kernel32.lib is actually missing in the VS 2010 lib\amd64 directory, I checked, but there is one present in the Windows 7.1 SDK lib\x64 directory, I checked. I guess though, contrary to my expectations these libraries are NOT the same libraries and so aren't interchangable and so I really do need to some how but a copy of MS Visual Studio 2010 Professional if I'm ever going to compile those dlls as 64-bit plugins.
    As luck would have it, I have an old Microsoft Visual Studio 2010 Professional key so will just use that key but before I do, If someone would like to correct me on the above I'm all ears since it's said to work using that method as well.
  • OmnifluxOmniflux Posts: 434
    I don't know about editing vsvarsamd64 as I launch everything from inside Visual Studio, but I can launch the "Windows SDK 7.1 Command Prompt" shortcut, run "setenv /Release /xp", and all the environment variables are setup correctly.
  • MehdiZangenehBarMehdiZangenehBar Posts: 140
    edited March 2025
    I prefer cmake to configure Visual Studio.
    I can send you the basic configuration if you want.
    Post edited by MehdiZangenehBar on
    OK, thanks. I will try the Windows SDK 7.1 Command Prompt to see it can compile the samples.
    Yes, could you please? I am a UNIX guy and knoow nothing of all the Windows OS variables their different environments need. I am going to PM you my email address.
    I already ordered the MS VS 2010 Professional DVD but lucky it only cost $15 since I have a key already.
    OK, @MehdiZangenehBar, I got your response to my PM. I agree, could you post in the forums your working configuration for VS C++ 2010 x64(.i.e. amd64) architecture for the cmake setup so I can compile the DAZ Studio plugins as 64 bit? Thanks a lot.
    Thanks, again, I tested it and it works fine. I will compare the Windows SDK 7.1 command prompt environment variables with what I  was trying to setup yesterday.
    edited March 2025
    OK, this is a very basic project that i build using Visual Studio Code.
    Visual Studio 2010 Ultimate installed.
    VSCode and it's C++ extensions installed.
    CMake 3.24.4 installed, this is highest/last version that will support VS 2010.
    please download entire project, open up the cmakelist.txt and change the SDK path to your installed SDK.
    I am windows user, so I am not sure what you should change based on your operations system, so check the files one by one, specially c_cpp_properties and CMakeLists
    So, if everything works , you can open folder using VSCode,There is a shellaunch file build.ps1, you can run .\build.ps1 command in powershell terminal in VSCode.
    plugin will be build in Kodak folder in daz plugin folder/kodak/kodak.dll
    then a kodak menu will be added to the daz menus. then you can run action from it.
    note that if you build this way, no need to open Visual Studio editor at all. all can be done using VSCode
    zip
    zip
    BasicProject.zip
    3K
    Thanks, the Visual Studio 2010 Professional DVD I ordered is shipping from eBay tooday so I'll be able to try you Basic Project soon. Thanks very much!
    edited March 2025
    OK, some notes for next time what worked for me to build the DAZ Studio 4.5+ SDK:
    I am running the newest Windows 11 plus patches and an AMD Ryzen 7 5700 CPU with 128GB RAM and a PNY GeForce RTX 4070 12GB GPU..
    1) I installed all the toolkits and DAZ Studuo 4.5+ SDK as directed in the link to the instructions that Richard Haseltine gave above.  The document will be found also in the SDK documentation, e.g. here is where my copy of the document is on my  local hard drive, yours will by in the location you have installed the DAZ Studio 4.5+ SDK:
    1) I ordered on eBay a 15 year old copy of Microsoft Visual Studio 2010 Professional for $15. It came from an MSDN Subscription DVD that the seller was parting out.  The seller supplied no product key but I owned a product key myself so that wasn't important. However, I had forgotten that MSDN supplied Visual Studio and other products supplied on the MSDN subscription were made by Microsoft not to require a product key anyway so my product key wasn't needed to use Visual Studio 2010 Professional. That should inform you if you even need to buy an old EOL Microsoft product in the future and all you can find is the product on a CD or DVD being parted out of an old MSDN subscription. On first startup I configured Visual Studio 2010 Professional to use a setup best for C++ (rather than C# etc).
    2) I installed the Windows 7.1 SDK and the patch for the VC++ 2020 x64 compiler linked to above by OmniFlux:
    3) I allowed Windows 11 to update my system for the many patches required after a full install of the 15 year old MSDN Visual Studio 2010 Professional and rebooted.
    4) I started the CMake 3.24 GUI and configured it to use the DAZ Studio 4.5+ SDK directory and build diirectory, plus I specified manually build to the x64 target withh the v100 flag in thhe CMake-gui. I generated. The I had to manually add the location of my DAZ Studio .EXE location for the build process to copy liinked programs and plugiins to the DAZ Studio plugins location so I can test them. You'll see that VARIABLE in the CMake GUI list of environment variables you eiither paste the correct path in or you can navigate to it with a File System browser. Then you tell CMake-GUI to generate the make files again. You will have to add permissiions for you as a Users\ in the Windows security space to be allowed full access (probably get by with less but I'm not worried) in your DAZ Studio EXE directory location. Newer versions of CMake than 3.24 are missing the option for Visual Studio 2010 compile chain.
    5) OK, now you're ready to go. Open Visual Studio 2010, open a project and navigate to the DAZ Studio 4.5+ SDK build/x64 directory the DAZ Studio SDK build instructions had you create earlier. Open the .sdl file. The target should already be x64 but change from debug to release (debug is OK too, you are just getting this setup so you can edit your own plugins it you like) and then tell VS to build all. It does that and copies the plugins to the DAZ Studio EXE directory plugin.
    6) Open DAZ Studio and go to About Installed Plugins and they should all be there and green. If they are not the build failed and didn't copy them there or the build succeeded and had no permissions to copy them there or both the build succeeded and it did copy them there but the plugins are red because they are Win32 instead of x64. Check and coorrect your cMake configration.
    That's it.
    I didn't bother trying to get the build process to work with VS 2022 Community or VS Code 2022 yet, but I think it will be relatively straight forward.
    Thanks everyone for your help.
