Add a note
Let's say you have a Daz item of clothing and you want to add a reminder note to the clothing icons about there being related prop items too. How do you do that?
    You could replace the ".tip" file with an image file that you created containing the text of the note.
  • or if there isn't a tip file add one - filename.tip.png, 256 pixels square. You could also add a tag (e.g. Has Props) by selecting the files and entering it in the Tags area at the bottom of the content pane - it is, I think, collapsed by default.
  • RandomRandom Posts: 257
    Thanks you both. That'll work.
