Brick Size
When I attempt to use brick shaders- ...on a wall, for example- the bricks are WAY to large.
Is there product that has smaller size bricks, or allows one to reset the size, so they look normal?
...or a setting that can do that?
  • crosswindcrosswind Posts: 10,358
    Just go to Surfaces pane, shelect the surface, increase the values in Horizontal Tiles and Vertical Tiles.
  • felisfelis Posts: 6,651
    I would assume that the shader is seamless, so just increase the tiling in the surface tab.
  • dash2128dash2128 Posts: 736
    So there IS a way, eh?
    I'll give it a try, thanks!
