.obj import
Can anyone suggest a percentage or how I get a .obj imported into DAZ Studio 4.22 so I can see it at a reasonable size? Cheers
  • That will depend on where it comes from (which application exported it) - OBJ has no inherent scale (or it does, but hardly any applications resepct it). One unit to one metre is common, try the modo preset.
  • crosswindcrosswind Posts: 10,313
    Also better check from which software OBJ was exported, then convert percentage based on different Unit Measure. For instance Daz's default Unit is Centimeter, if the source software also uses Centimeter, you just keep 100%. If the source software uses Meter, then 100% * 100.
    If you don't know the origin of OBJ file, open OBJ file with Notepad / Notepad++, you'll see the relevant info. on the top.
  • lilweeplilweep Posts: 2,877
    change the scale when importing or re-scale after import.
