• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
blender 4.0.2. to Daz obj?
3dQuill3dQuill Posts: 35
January 2024 edited January 2024 in Blender Discussion
 Does anyone know the settings for exporting morphs back to Daz from Blender 4 obj export (not lagacy obj export)? I finally upgraded to Blender 4.0.2 and it doesnt have the lagacy obj exporter that I've been using. Now I keep getting geometry doesn't match in Daz Morph Loader Pro, even if I dont touch the mesh at all. I've tried tons of different settings in Blender export, no luck. This pic shows nothing selected in Blender export because I even tried that.
1754 x 668 - 317K
Post edited by Richard Haseltine on January 2024
  • felisfelis Posts: 6,617
    January 2024
    If geometry didn't match, is usually caused by exporting in High Res, or if it is a character, to forget to remove eye lashes etc.
  • 3dQuill3dQuill Posts: 35
    January 2024
    No, it's a simple shirt at base res. I've done it tons of time with the legacy obj, but they got rid of it and the settings or different in 4.0. I'm just going to stay with 3.6 until I figure it out.
    January 2024
    The prime difference to legacy, is they have removed 'keep vertex order' as a check box as it is default.
    If it is a shirt, have you then removed e.g. buttons attached with rigid foloower nodes?
  • lilweeplilweep Posts: 2,879
    January 2024
    why is shirt.obj 17mb but shirt1.obj only 6mb? maybe you forgot to select all...
  • PadonePadone Posts: 4,371
    January 2024
    I tried to make a simple morph for the basic tank top in the G8 package, and it works fine here. For a morph you only need to export faces, the other data is not necessary and may be what it is giving troubles. I'm attaching the daz and blender options I used.
    In some rare cases the daz geometry is not good for blender and it needs to be validated, this means blender may change the vertex order on import to fit the internal data structures. This may depend on the application the PA uses to model the asset.
    459 x 483 - 62K
    276 x 519 - 35K
  • crosswindcrosswind Posts: 10,351
    I would suggest the safest settings for exporting / importing OBJ as below. (Geometry Only) Then save it as a Daz Operator Preset.
    Make sure the figure / prop in DS has no fitted geo-graft on it otherwise the geometry won't match...
    2024 x 1398 - 516K
    2560 x 1400 - 640K
    2560 x 1400 - 627K
    Post edited by crosswind on January 2024
    January 2024
    Why do you export UV and normals to create a morph?
    Because 1st, that's default options which has no impact to creating morph. 2nd, sometimes I do need them for other tasks, so I saved them as my Daz Preset. Then I don't have to check / uncheck them from time to time.
    If one doesn't need them, just uncheck them from the preset.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
