Bloom Filter Help
I am making an image playing with DOF and the bloom filter, When I am rendering after about 40 minutes this happens to my image....Any ideas why this is happening ?
2864 x 1883 - 520K
  • felisfelis Posts: 6,625
    Not something I have seen before.
    Are you using denoising?
  • beachlegsbeachlegs Posts: 532
    edited January 2024
    Hello yes it is turned on.
    These are my settings I used
    600 x 600 - 62K
    You said that it started after a while, which got me thinking of denoiser.
    There was an issue earlier with denoiser and certain drivers, so it is possible that this is something similar.
    Which driver version are you using?
  • Korpin.SulatKorpin.Sulat Posts: 414
    edited January 2024
    Doesn't that post-denoiser alpha do some janky stuff sometimes? I thought they wouldhave removed that... Uncheck it and give it another go.
    Post edited by Korpin.Sulat on
    edited January 2024
    I did that but again everything was ok then it seemed to explode into this bright light again...I might have to give it a miss this time :(
    Driver version?
  • Edited to fix quotes.
  • AgitatedRiotAgitatedRiot Posts: 4,768
    I see the Bloom is set to One; how about Section caps and Caustics? I have gotten this before; I would delete the environmental and tone mapping, set render settings to default, and then redo the settings. I think it was one of the two I mentioned: section caps and caustics.
    Driver version?
    Somewhere around 536, I do believe.
    Well very close Green image with iRay post denoiser with NVidia drivers 535.98 - Daz 3D Forums
    edited January 2024
    Thank you, I will go and try that now :)
    Bloom set to one and bloom set to.001.
    1920 x 1080 - 289K
    1920 x 1080 - 141K
  • GordigGordig Posts: 10,822
    Yeah, DS's default bloom settings are WAY off what they should be.
    Default is 0.050
  • crosswindcrosswind Posts: 10,351
    Bloom Filter Radius 0.015 ~ 0.025 works well in most of the cases... and try to increase Bloom Filter Threshold to  >7500.
    Besides, pls check if you were rendering with CPU...
    Thank you all for your help I really appreciate it, I have not used bloom much so I had no idea what the setting should be I will go and have a play :)
  • FishtalesFishtales Posts: 6,238
    edited January 2024
    This might help.
    2940 x 2000 - 834K
    Post edited by Fishtales on
    edited January 2024
    Fishtales said:
    This might help.
    This will help me a lot thank you so much my friend :)
  • Bloom Filter Settings table will come in handy.
