Plugins (Instancing)
I'm sure that this has probably been covered, but I could not find it.I just purchased Bryce 7, and the instance grass plugin. How do I install the grass plugin ?
Post edited by Chohole on
Which grass plugin is that? Normally there are no actual plug-ins for Bryce.
Is that what you bought? http://www.daz3d.com/bryce-instance-grass
If the product you mean in this one http://www.daz3d.com/bryce-instance-grass then I think that you will get better responses in the Bryce forum, so I shall move your thread over there, and I will try to find you a link to A tutorial on using the Instancing Lab, which is built into Bryce.
And I found it Instancing Tutorial by Rashad Carter
The product that you have bought just needs to be installed into your Objects preset folder
And here is a PDF compiled from Rashad Carter's "How to use the Instancing Lab in Byce 7.1 Pro — A complete tutorial" mentioned above: https://horo.ch/docs/guests/pdf/InstancingLab_Rashad.pdf.
Thank you for the responses. As simple as copying folders. Thanks to all, the tutorial will be very helpful. I have been away from Bryce for a number of years, so must reacquaint myself.
