Help with AniMate?
DarthD
When placing Aniblocks together, the character jumps forward a little at each block transistion. Even if it is the same block repeated. I tried a walk cycle, three times back to back, and every time the next block starts, the character jumps a little forward. I had asked about this problem a long time ago and someone helped me but I can't remember the fix or find where I asked. It's been a while since I've used AniMate..
I found a way that works. If I combine the aniblocks they flow smoothly. I don't know if this is the only way to fic it or not. I thought there was another way.
I didn't answer your original post because it does not happen to me at all. I put three walk cycle blocks in the animate timeline, and they worked with no jumps, I don;t know why yours jumps at all.
I am using DS 4.8.0.59. Have you made sure that there are no gaps in the timeline between Aniblocks, just a thought?
Yes, I see no issues. Some aniblocks work fine without jumping. Others don't.
