Install Manager: Select multiple items?
DrHemulen
Hi
I'm starting over from scratch and don't want to install all the old genesis 1 and similar old stuff. I can sort by date, but how do I select multiple entries to download and install? I tried the usual stuff with holding down shift, crtl and alt, but nothing seems to work.
There's a "select from csv" in the right click menu, but I can't find documentation on the format.
You can output a CS, to compare. There isn't a way to multi-check as far as I know - but if you use the filter box to show a subset that includes only items you wish to install you can then click the master checkbox to select all of them, which may be a way to handle it.
