Multiple Smoothing Modifiers? [RESOLVED]
OminousAutumnOminousAutumn Posts: 405
edited December 2023 in New Users
Is it possible to create 2 or more smoothing modifiers to ineract with a single object? I have Ghost Dynamics but can you create a scenerio in which two figures both seperately interact with one sofa or bed without Ghost dynamics? So far I can only have one figure create indentation on a bed, but why not two? Cheers.
Post edited by OminousAutumn on
  • barbultbarbult Posts: 27,565
    The Parameters pane only allows selecting one collision item (the figure in your example) per object (the bed in your example). You could use Mesh Grabber or a dformer to manually make an indentation in the bed, if the mesh density of the bed is adequate.
  • GordigGordig Posts: 10,809
    I don't know if it would work, but you could try grouping two figures and setting the group as the collision item.
  • ElorElor Posts: 4,143
    Jay Versluis has a tutorial on the subject:
  • crosswindcrosswind Posts: 10,311
    A simple way ~
    With Collision Item set to Figure A, export sofa / bed to OBJ file and import as a "sitting morph for figure A" with Morph Loader Pro, dial it. Then set the Collision Item to Figure B. In this way, you can make multiple "morphs" on sofa / bed for multiple figures...rather than "merging figures".
    2017 x 1397 - 460K
    I tried this and had no luck. Thank you for the suggestion :)
    Awesome thank you.
