emissive.
is it difficult to make a material or skin emissive on a G9 Figure? I know I can purchase some itmes but I would like to make my own! Cheers
  • If it uses the Iray Uber Base shader just set the Emissive Colour to non-black, optionally with a map to limit the effect, in the Editor tab of the Surfaces pane and then adjust the light properties below that.
  • Richard thank you for your reply. Can you expand on this? Do you mean I do not use a G9 Base Skin for emissive purposes? Is there a UBER skin for G9 Figures? Cheers
  • The PBR Skin sahder, used by a lot of recent characters, does not have emission. You could use a Geometry Shell, with regular Iray Uber, to layer emissive areas on top of the base skin.
  • crosswindcrosswind Posts: 10,355
    edited December 2023
    Or check this https://www.daz3d.com/pbr-skin-plus, if you prefer to PBRSkin...It's PBRSkin plus with emission enablement
    Post edited by crosswind on
