[SOLVED ] Strange problems with DIM and WIN10
Muscleman
Ok - The new PC is fixed (it seems), obviously now I have to install everything again, but while Blender didn't give me any problems, but DAZ studio doesn't seem to want to hear about it from the DIM, it keeps telling me that I have to RETRY (Try again) but that I have to Do? And so I tried to install DAZStudio and it told me that it was blocked by I don't know what, I downloaded from the D|S site and a window popped up which however I couldn't read because I involuntarily clicked forward, and so I gave it the 'ok and it installed the program but it doesn't want to install the content I need from the DIM XD...What have I done? How do I solve it? Thank you!
1640 x 772 - 226K
Post edited by Muscleman on
When it says "retry" I think it usually is because the servers are busy / not available.
Try to wait a short while and then try again.
DIM has a log file and a helper log file that might tell you something about what is wrong. You can access the logs from the gear icon in DIM's upper left corner.
Were you careful to set up the paths in DIM before you started downloading things? There are paths to configure for Download, Installation, and Applications.
Upper-right.
Find it, but Log say me this: SSL Error: Unable To Get Local Issuer Certificate - also, I don't change the default setting too
You probably need this GoDaddy certificates issue
If it's also followed by a line with "SSL handshake failed" then the current fix for that is to install the GoDaddy certificate - see more info in this thread.
EDIT: Oh, 1 minute too slow!
Thanks you all! that fix it!!
