• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic and Blender 4.0 - should I upgrade Blender from 3.6 ?
Singular3DSingular3D Posts: 671
November 2023 in Blender Discussion
Just in progress setting up a new PC with Win11 and I wonder, if Diffeo can be used with 4.0 or if I should stay with 3.6 for now.
I have tons of Daz assets and I want to transfer them and enhance them in Blender, but there are significant changes regarding material and other things.
I'm unsure if I can go already with 4.0.
Any experience?
  • hardwire666hardwire666 Posts: 79
    November 2023
    As of a couple days ago the best route was to use 3.6 to import and get things set up and then use that blend file in 4.0. The weekend is when I typically work so I've been out if the lool for a few days and this may have changed for all I know.
  • PadonePadone Posts: 4,315
    November 2023
    Diffeomorphic 1.7.2 supports Blender 4.0, unless new bugs are found but that's usual. However, as for converting 3.x projects to 4.x personally I wouldn't go that way, because 4.x is very diferent from 3.x. For production it is better to keep 3.x projects in 3.x and eventually do new projetcs in 4.x.
  • Singular3DSingular3D Posts: 671
    November 2023
    Thanks for the reply. I don't have many projects in 3.6, so I will go with 4.0 to set up my new project space. This will be a blast! :)
  • ValiskaValiska Posts: 176
    December 2023 edited December 2023
    I'm transferring my library over. I'm doing inanimates and plants now, not characters or their wardrobes. I switched over to Diffeomorphic 1.7.3 and Blender 4.0 about a week and a half ago.
    So far, no particular problems. I don't know what I'm going to think of Blender 4's shader changes when I start adjusting them, but the conversions look as good as Diffeo 1.7.1 and Blender 3.6.5.
    I start by converting any old 3Delight textures to Iray using RSSY's converter. I've altered the order of operations in the options a bit, to pick which shaders get priority. The only recurrent error with this script is that if an entire object -- light bulb and lamp hardware alike -- is named 'light', I uncheck the hardware surface, don't autoconvert it, and pick a shader for it manually (else, the entire object will come into Blender bright white). (You can fiddle with the wildcard expressions that guess what Iray shader the surface should get, or add new ones, but so far that hasn't seemed desireable. There've been a couple of other cases where I applied shaders to particular surfaces by hand, but the standard guesses are usually pretty good and I accept them.)
    Then I do the Diffeomorphic conversion in Daz Studio.
    Then I import the converted model into Blender and save it, along with the store illustrations and the texture maps in separate folders, so I know what it's supposed to look like. Occasionally I get a Python error from Diffeomorphic on Blender import, but so far that hasn't prevented a useful model appearing in the viewport.
    I expect, when I start to render these converted models, that I'll want to adjust some of their materials for the specific rendering. But right now I'm not doing that because I want to get my library over, and they mostly look OK.
    You have to turn transparency on in Eevee to see some of the textures correctly in a Blender preview.
    Post edited by Valiska on December 2023
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
