• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Linked objects in new scene taking FOREVER to render
jwcjaygainesjwcjaygaines Posts: 72
November 2023 edited November 2023 in Blender Discussion
This is a follow-up to one of my previous questions on here regarding linking versus appending. I have been linking different things into new projects instead of appending to save file space. However, a new problem has arisen. In my current scene, I have five different linked objects. Usually when I render the individual objects in their respective projects using F12, it takes a couple of minutes (depending on size and sample count), and only uses about 8K under the Task Manager for memory. With the current scene, it's not even rendering, usually just crashing, and the memory is at 25K+ and keeps climbing. Is this the tradeoff between the two methods of importing? Or am I doing something wrong?
Post edited by jwcjaygaines on November 2023
  • Richard HaseltineRichard Haseltine Posts: 111,929
    November 2023
    It isn't that the problem scene is using an Out of Touch hair or hair shader, without the updated shared file?
  • jwcjaygainesjwcjaygaines Posts: 72
    November 2023
    Hi Richard! Thanks for replying. I'm not exactly sure what you mean. I should clarify that I'm using Eevee in Blender 3.0 for both scenes. As I mentioned, in their own individual files, they render just fine. It's only in the "merged" file that the issue arises. As far as I know, none of the settings have changed, as I am using a custom scene setup I created awhile ago. I'm currently trying to render the scene after appending the objects instead of linking, and it's the same issue, so I've ruled out the linking versus appending tradeoff theory. My next step will be to see if I can render each individual piece in the new scene. All the hairs are made with the particle system and have a material that I made using a tutorial from Pixelica on YouTube.
    November 2023
    Sorry, I was stuck in DS-mode, where the hair issue is currently a problem for soem suers (dpeneding on how, and in what order, they installed their cotnent). It is relevant to Blender.
    November 2023
    Ah, okay. Well I tried it multiple different ways that I mentioned above, and it's still not working. I even downloaded Blender 3.6 and will give that a try later. I just honestly don't like how they redid some of the material nodes, and the removal of the pose library into assets. The last part especially!
  • PadonePadone Posts: 4,371
    November 2023
    As you discovered yourself, as for rendering time and resources it doesn't matter if you link or append, blender will load all the assets in the scene anyway. Of course you can render the single assets, but together in the scene they take more memory. The difference with linking is if you modify the original then all the linked will follow, also linked scenes are small files on disk, that doesn't mean small ram when you load the scene.
    If you don't have enough ram/vram to render the scene then you can try composition, that is, render separate objects then compose the images in a paint program.
    November 2023
    Hey Padone! Good to see you again! Yeah, I'm guessing it's a RAM issue. Kinda depressing, though. What's weird is that my computer seemed to be rendering just fine before, but then Dell started screaming that I needed to update drivers, and it's been all downhill since then.
    November 2023
    So I tried something (that I should've thought about when this all started). I went back to other projects I had made before this one. Those all seem to be rendering just fine. It's just the most recent two. I'm guessing it has something to do with the models themselves. Maybe there's a glitch in the Matrix. I'll be going back later and redoing the projects to see if I get better results.
    November 2023
    Some daz assets can be much heavier than others, especially HD figures and hairs. You can check the number of polygons and textures size, there's also the "scene information" addon included in blender that may help keeping track of resources.
    November 2023
    I think I may have discovered the problem. When I use Diffeomorphic to convert the fibermesh hairs to particles, I tried to match the number of segments in the render option to what the group says after it converted and I combined them. For example, the scalp hairs had 17 segments, so I turned up the render segments to 17 (beyond the 9 maximum default allowed). Turning those down to 5 seemed to work, and honestly, I don't see any difference. Since the model is linked in the new project, I'm gonna go back and see if that fixes the issue.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
