Prop saving error (resolved)
felisfelis Posts: 6,656
I got an error trying to save a prop, and I don't really understand how the error origins.
The error message was a couple of lines repeated a number of times
2023-10-22 21:20:43.107 [INFO] :: 396 unmatched vertices out of 396.
2023-10-22 21:20:43.107 [INFO] :: 402 unmatched facets out of 402.
And finally a 'failed to save'.
Background is I have a rigged V4 object (an earring) I wanted to convert to a wearable preset.
So I converted the figure to a prop, and parented it to a character, and saved it as a wearable preset. Looking in the file I could see it had saved it to the data folder with a "weird" name (I was in doubt if it could use the original data file). So I would save it as a prop with a proper name, and then I got the above mentioned error.
I know I can just export and reimport, but I am curious why it happened, and if it can be corrected (within Daz Studio).
Post edited by felis on
  • crosswindcrosswind Posts: 10,358
    Dunno the reason and would like to know as well. Sometimes rig with converting from TriAx to General Weight might work.
  • felisfelis Posts: 6,656
    That was also my idea, but couldn't find a way of converting a prop.
    So I converted the prop to a figure and back to a prop, and then it worked...
    Okay, got it. Thanks !
