Create New Camera Options
Would some one please be good enough to explain the difference between these Create New Camera options: Copy Active View : <PerspectiveView> and Apply Active Viewport Transforms : <Perspective View>? Thanks to one and all, very much indeed!
  • The latter just copies the position and orientation of the perspective view (you can't select it as a node to se them, but it does have the standard properties): all the camera-specific settings are at default. The former copies all properties from the Perspective View, including things like Focal Length.
  • barbultbarbult Posts: 27,586
    If you have your view just the way you want it, but realize you are in Perspective view, instead of using a camera, create a new camera and choose Copy Active View: Perspective View. Then change to view through your new camera. When you save the scene, the camera view will be saved. When you save a scene, Perspective View is NOT saved. So creating that camera is important if you want to save the scene and reopen it to the same view.
  • @ Richard Haseltine, @ barbult Thank you very much for your answers.  I do really appreciate your taking the time to explain.
