Spot Lamp
in Freebies
I was derping about in Sketchup and made a simple spotlamp with rail. It's not rigged but there is a hierarchy, so you can rotate the lamp on Y or Z and point it wherever you like. You can also join rails together or just use the rail itself to make a rig with a lamp every now and then. The lamp mat is emissive. All other mats are Daz Uber based.
To rotate around Y (left/right), select the Vertical Pin and use Y rotate. To rotate around Z (up/down), select the Horizontal Bracket Pin and use Z rotate.
zip
zip
pickle spot lamp.zip
212K
Thank you so much! :)
