ERROR PATH WAY
Install Manager cannot find a required path. The package for "Bryce 7.1 Pro -
Golden Lighting" requires that the installed path for "Bryce 7 Pro, 7" be defined.
Make sure that a path for this application is
present on the "Applications" page of the "Settings" dialog, then try again.
  • Install Manager cannot find a required path. The package for "DSON Importer for Poser (Win 64-bit)"
     requires that the installed path for "Poser Pro 2014, Pro 2012 (64-bit)" be defined.
    Make sure that a path for this application is present on the "Applications"
    Have you set your install manager up to show the required path?  It needs to know where you installed Bryce 7 to.
  • frank0314frank0314 Posts: 15,120
    You need to enter in the file path of your main Poser folder in the applications tab.
    555 x 512 - 58K
  • thansk so much ;)
  • thanks so much ;)
  • Merged threads since they were the same basic issue.
