Bootup Issues
Went to reboot Daz today and got a message to update.
Accepted the message and now Daz boots as such.
Tried rebooting 3 times. No improvement.
What's up guys?
1801 x 1007 - 133K
  • kyoto kidkyoto kid Posts: 42,509
    ...interesting, in the upper left corner it indicates the current version is Daz Studio 4.20 Pro.  It should read Daz Studio 4.21 Pro. (I just opened 4.21.0,5 and it notes the latter). So possibly the automatic install was corrupted somehow (I usually don't trust auto installer routines)?   I also turn off turned off auto updates and only install through through the IM.
    The only thing I can think of is uninstalling the bad copy then reinstall the newest version directly through the IM.
    What OS are you on?
  • felisfelis Posts: 6,669
    And make sure that Daz Studio has fully closed down before upgrading. It might take several minutes after you have closed it.
  • crosswindcrosswind Posts: 10,360
    Usually such a white UI means a corrupted installation or some application related files are missing. Fully shut all instances of DS, then download the IM package and re-install it thru DIM.
    As Felis said, usually because DS was still running (or at least still shiutting down) when the update was installed.
  • Figured it out...
    For whatever reason, the new update changed my "Layout" and my "Perspective View". Probably zero'g them.
    While in the blank workspace I changed the workspace layout back to my custom setting and changed the perspective view back to texture shaded and all is working again.
