A bug?
I experience this for the first time.
Everything looks fine. Then I rotate my viewport. PUF! Everything is black.
Load the scene again, looks fine. Rotate my viewport. PUF! black again.
Anyone knows whats going on?
    You are probably moving the viewport inside an object. If not you probably need to provide more info.
  • JamesJames Posts: 1,191
    Ah nevermind, it seems that somehow I get thrown out of my room far far away, and the environment outside was pitch black.
  • felisfelis Posts: 6,635
    You can try click an object in your scene and then the plus in 4 corners (frame view) in right side of the viewport. Then you will orbit around that object.
