Does Daz Central replace Install Manager?
The Install Manger and DIM are the same thing correct?
  • nemesis10nemesis10 Posts: 4,056
    Daz Central is sort of a simplier less flexible version of Install Manager (strictly speaking Daz Install Manager or DIM).  If you want something that you don't have to configure, opt for Daz Central; if you are going to do customization such as placing libraries on external drives etc then use DIM
  • lilweeplilweep Posts: 2,883
    I still use DIM.  Works fine.
    Not even DAZ itself is pushing Daz Central anymore, they have changed the page "Download Studio" to one that promotes DIM instead of Daz Central.
  • crosswindcrosswind Posts: 10,359
    As above, quite a lot of us will suggest 'no go' for DC. DIM is the only best companion for you ~~ It won't set you up as long as you have it configured correctly...
  • symsonsymson Posts: 12
    Thanks.
    Thanks. Good to know.
    Thanks. Looks like it is unaimous. Use DIM.
