Hexagon to DAZ Studio Link
For quite some time, when returning a file to DAZStudio via the Link, there is no menue with an option for Reverse Deformation anymore.
Why has it gone?
Is there a version, that brings it back?
The DAZ to Hexagon bridge is pretty much useless without it.
  • Saxa -- SDSaxa -- SD Posts: 882
    It's still in same place. Use all the time. When send back to DAZ, when you name your new morph, and attenuate or whatevs, the reverse deformation is there.
    You may have to click once on morph name  to open the submenu though.
  • MasterstrokeMasterstroke Posts: 2,510
    edited June 2023
    Ahm, no. There is absolutely no option for Reverse Deformation.
    I know for a fact, there used to be one looking exactly like the morph loader dialog, but it has changed for areason I don't understand.
    I am on DAZ studio 4.21.0.5 and Hexagon 2.5.2
    396 x 238 - 44K
    Post edited by Masterstroke on
  • Richard HaseltineRichard Haseltine Posts: 111,715
    Check that, in Daz Studio, Edit>Preferences>Bridges tab has the advanced options enabled for Hexagon.
    Goes to show once again the value of having a DAZ affiliated mod here at forums.
    When set up my 2nd PC again just went through everything right away at setup and set it all to advanced, including that DS pref, and timeline, and show hidden morphs in parameters etc.  So totally years ago that had to do that initially.  Not a good use of my memory to remember that. Just know it works.
    Does seem odd in this case for bridge that you gotta set that to advanced.  Reverse Deforms seems kinda basic-important.
    +1 for value of a regular kind DAZ moderator.
    Aaaah, there it is. Thank you.
  • jkrimmingerjkrimminger Posts: 21
    How do you link hexagon to daz3d? Tried going through daz install program. Does work. Trying manually. Had it, but lost connection. The bride is lit green.
    Link with hexagon after downloading fromdaz install does work.
    Doesn't work
    How are you installing?
