Content library assets loading issue
Hello,
I've faced an issue where assets in the content library are not loaded (for instance, after rendering process).
The folder structure is preserved, however, the list of assets is empty and I cannot use any of the assets. To fix the issue, I usually save the scene, and then the items are loaded properly.
An example could be found on the screenshot, in the "0. Outfits" folder I should be able to see some assets in the list below, however, as you can see, the list is empty (the same behaviour is expected for all the folders):
As for the system configuration: 42 gb RAM, RTX 3070, AMD Ryzen 9 5900HS + 1TB SSD.
Are there any ideas on how to fix the issue, so the assets are loaded properly?
  • Richard HaseltineRichard Haseltine Posts: 112,003
    The scroll bar is at the bottom, however, as if it has a lot of entries - what happens if you drag it up? Or right-click on the folder and select Refesh?
  • crosswindcrosswind Posts: 10,357
    That's a 'routine' of DS... only RMB menu - Refresh works...
    Hello, appreciate your comment. It's definetly not a scroll bar issue (nothing happens).
    As for refreshing the page, I have not tried it yet. Once the issue occurs, I'm going to check that option, thank you.
