character's poses
Why if I apply pre-set poses to the character, does it lose its physical characteristics?
For example, the character I built has some modifications to the body applied by the basic parameters of the software, plus others modified by the addons. For example, a parameter is that of the SCALE this is reset to 0 after having applied a downloaded pose.
What must be done to prevent this from happening?
  • Richard HaseltineRichard Haseltine Posts: 111,965
    Shaping should not be touched by a pose, but scale is not a shaping control and may be. You could save a pose preset with the scale settings before aplying the pose (use the options diualogue that appears after setting the file name to be selective, the dialogues option menu has a commend to check>Check All Scales if you firast uncheck all) and reapply that after the pose (but bear in mind that changed proportions may require adjusting the pose to balance).
  • npsimonenpsimone Posts: 33
    edited April 2023
    Excuse my inexperience, but I couldn't do it.
    1) I start from a basic pose that I made which I call POSA0
    2) SAVE AS> POSE PRESET.
            In the PROPERTIES option which of these options do I choose or what do I do?
    Hip
    General
    Hidden
    Pose Controls
    I tried various attempts but I don't get any valid result.
    If the options are all selected, it obviously saves the entire POSA0 and if I apply it to that of other authors, the latter is replaced by mine.
    I tried saving by selecting a single item at a time, but I didn't get any satisfactory result.
    Post edited by npsimone on
    Deslect (uncheck) everything, then use the option menu (the littlie button on the right edge, just above the figue hierarchy panel) to select scales.
